[GRASS-dev] Re: [GRASS5] Re: auto-locate EPSG
Markus Neteler neteler at itc.it
Thu May 11 11:33:20 EDT 2006
Hamish wrote:
> _BUT_ $PROJLIB (from --with-proj-libs=) generally isn't set unless the
>user has it somewhere weird. ??? For the standard places ld.so.conf path
>is used without -L -I and the lib test passes without further complication.
>Hamish
I have hacked
 lib/init/Makefile
to avoid the currently unpleasant situation that PROJSHARE remains
completely
undefined if --with-proj-share isn't used. Now, instead if leaving PROJSHARE
empty and creating epsg_option.tcl and make_location_epsg.sh incorrectly,
it is set to /usr/local/share/proj. If PROJSHARE was defined via configure,
that directory is used.
Hoping for a better solution,
 Markus
