[GRASS-dev] [bug #4451] (grass) New options for g.region
Request Tracker grass-bugs at intevation.de
Thu May 11 15:49:14 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4451
Subject: New options for g.region
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: CVS updated 20060511
The following patch adds options to g.region to set the number of rows and columns of the region.  Options are:
rows=
cols=
size=
rows= and cols= are self-explanatory, size= sets both rows and cols to the same value
Index: main.c
RCS file: /home/grass/grassrepository/grass6/general/g.region/cmd/main.c,v
retrieving revision 1.23
diff -u -r1.23 main.c
--- main.c	6 May 2006 23:13:46 -0000	1.23
+++ main.c	11 May 2006 19:41:27 -0000
@@ -34,6 +34,8 @@
 	int print_flag, dist_flag;
 	int set_flag;
 	double x;
+	int ival;
+	int row_flag=0, col_flag=0, depth_flag=0;
 	struct Cell_head window, temp_window;
 	char *value;
 	char *name;
@@ -63,7 +65,7 @@
 		struct Option
 		*north,*south,*east,*west,*top,*bottom,
-		*res, *nsres, *ewres, *res3, *tbres,
+		  *res, *nsres, *ewres, *res3, *tbres, *rows, *cols, *size,
 		*save, *region, *view,
 		*raster, *raster3d, *align, *zoom, *vect;
 	} parm;
@@ -324,6 +326,33 @@
 	parm.save->gisprompt   = "new,windows,region";
 	parm.save->guisection  = _("Effects");
+	parm.rows = G_define_option();
+	parm.rows->key         = "rows";
+	parm.rows->key_desc    = "value";
+	parm.rows->required    = NO;
+	parm.rows->multiple    = NO;
+	parm.rows->type        = TYPE_STRING;
+	parm.rows->description = _("Number of rows in the new region");
+	parm.rows->guisection  = _("Resolution");
+	parm.cols = G_define_option();
+	parm.cols->key         = "cols";
+	parm.cols->key_desc    = "value";
+	parm.cols->required    = NO;
+	parm.cols->multiple    = NO;
+	parm.cols->type        = TYPE_STRING;
+	parm.cols->description = _("Number of columns in the new region");
+	parm.cols->guisection  = _("Resolution");
+	parm.size = G_define_option();
+	parm.size->key         = "size";
+	parm.size->key_desc    = "value";
+	parm.size->required    = NO;
+	parm.size->multiple    = NO;
+	parm.size->type        = TYPE_STRING;
+	parm.size->description = _("The size (number of rows an columns) in the new region");
+	parm.size->guisection  = _("Resolution");
 	if (G_parser(argc,argv))
 		exit(1);
@@ -726,6 +755,33 @@
+	/* rows= */
+	if ((value = parm.rows->answer))
+		if (sscanf (value, "%i", &ival) != 1 )
+			die(parm.rows);
+		window.rows = ival;
+		row_flag = 1;
+	/* cols= */
+	if ((value = parm.cols->answer))
+			die(parm.cols);
+		window.cols = ival;
+		col_flag = 1;
+	/* size= */
+	if ((value = parm.size->answer))
+			die(parm.size);
+		window.rows = window.cols = ival;
+		row_flag = col_flag = 1;
 	/* zoom= */
 	if ((name = parm.zoom->answer))
@@ -754,12 +810,12 @@
 		if (G_legal_filename (name) < 0)
 			G_fatal_error (_("<%s> - illegal region name"), name);
 		G_copy (&temp_window, &window, sizeof(window));
-		adjust_window (&temp_window);
+		adjust_window (&temp_window,0,0,0);
 		if (G__put_window (&temp_window, "windows", name) < 0)
 			G_fatal_error (_("can't write region <%s>"), name);
-	adjust_window (&window);
+	adjust_window (&window,row_flag,col_flag,0);
 	if (set_flag)
 		if (G_put_window (&window) < 0)
Index: local_proto.h
RCS file: /home/grass/grassrepository/grass6/general/g.region/cmd/local_proto.h,v
retrieving revision 2.3
diff -u -r2.3 local_proto.h
--- local_proto.h	19 Dec 2005 16:14:24 -0000	2.3
+++ local_proto.h	11 May 2006 19:41:27 -0000
@@ -1,7 +1,7 @@
 #ifndef GREGION_LOCAL_PROTO_H
 #define GREGION_LOCAL_PROTO_H
 /* adjust.c */
-int adjust_window(struct Cell_head *);
+int adjust_window(struct Cell_head *,int row_flag,int col_flag, int depth_flag);
 /* zoom.c */
 int zoom(struct Cell_head *, char *, char *);
 /* printwindow.c */
Index: adjust.c
RCS file: /home/grass/grassrepository/grass6/general/g.region/cmd/adjust.c,v
retrieving revision 2.2
diff -u -r2.2 adjust.c
--- adjust.c	9 Feb 2006 03:08:52 -0000	2.2
+++ adjust.c	11 May 2006 19:41:27 -0000
@@ -1,11 +1,11 @@
 #include <grass/gis.h>
 int
-adjust_window (struct Cell_head *window)
+adjust_window (struct Cell_head *window,int row_flag,int col_flag, int depth_flag)
     char *err;
-    if (err = G_adjust_Cell_head3(window,0,0,0))
+    if (err = G_adjust_Cell_head3(window, row_flag, col_flag, depth_flag))
 	char msg[100];
 	sprintf (msg, "Invalid region: %s", err);
Index: zoom.c
RCS file: /home/grass/grassrepository/grass6/general/g.region/cmd/zoom.c,v
diff -u -r2.2 zoom.c
--- zoom.c	9 Feb 2006 03:08:52 -0000	2.2
+++ zoom.c	11 May 2006 19:41:28 -0000
@@ -12,7 +12,7 @@
     int top,bottom,left,right,mark;
     double north, south, east, west;
-    adjust_window (window);
+    adjust_window (window,0,0,0);
     G_set_window (window);
     nrows = window->rows;
     ncols = window->cols;
-------------------------------------------- Managed by Request Tracker
