[GRASS-dev] [bug #4451] (grass) New options for g.region
Hamish
hamish_nospam at yahoo.com
Thu May 11 23:38:45 EDT 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4451
> Subject: New options for g.region
> The following patch adds options to g.region to set the number of rows
> and columns of the region. Options are:
> rows=
> cols=
> size=
> rows= and cols= are self-explanatory, size= sets both rows and cols to
> the same value
> +++ main.c 11 May 2006 19:41:27 -0000
> + int ival;
> + int row_flag=0, col_flag=0, depth_flag=0;
> + parm.rows->key_desc = "value";
> + parm.rows->type = TYPE_STRING;
why not use ->type = TYPE_INTEGER; and then skip key_desc?
Then the parser will ensure an integer was given and give a helpful
error message if not. Also you need to check that the value is >=1.
Will it adjust the region bounds or the resolution?
Hamish
