[GRASS-dev] Datum-addition
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon May 15 07:31:03 EDT 2006
Hello Stephan
On Mon, 15 May 2006, Stephan Holl wrote:
> Dear list,
> I have found several datum definition which are currently not supported
> by GRASS yet. However, I would like to implement them into GRASS.
> for example:
> DATUM|Ellipsoid Code|Region of Use|DX| DY |DZ |EX|EY|Ez
> India Bangladesh|EA |Bangladesh   |282|726|254|10|8 |12
> This values are found here[1].
> I found out that this needs to go into datum.table in lib/gis/.But the
> datums there only contain dx,dy,dz, not the ex,ey,ez values.
> What I am not sure about is the addition into datumtransform.table.
See the comment at the top of datum.table:
# If 99999 or above is given for all 3 parameters, then the parameters
# listed in this file will not be offered to the user and there
# must be at least one set of parameters for the corrseponding datum
# in the datumtransform.table file
If you only have a 7-parameter transform, then put 99999 for each
parameter in datum.table and make sure and put the transformation (in the
format towgs84=dx,dy,dz,rx,ry,m) in datumtransform.table
> Is it nessessary to provide more information there? How to transform
> into PROJ4-style (towgs84=)?
See above. Put in as much information as you can about the accuracy, area
covered, etc. But the paramters you have shown don't seem to be accompanied
by a scale factor m, so it looks supicious! Are you sure they work? Do you
have a test point? It's important to be very sure the parameters are
correct (preferably you have used them) before adding them to CVS as
people will use them and assume they are correct because they are in
GRASS!
Best regards
Paul
