[GRASS-dev] arabic try
Glynn Clements
glynn at gclements.plus.com
Mon May 15 23:10:08 EDT 2006
Hamish wrote:
> > - If I want to use another language like Arabic with interfaces in
> > grass, do I need to compile the grass?
> No. Language can be set at runtime.
> You do need the source code to help with translating new messages. (?)
Also, GRASS' text handling is quite primitive, and oriented towards
ASCII and ISO-8859-* encodings. At present, the internationalisation
support is limited to:
1. The use of message catalogues.
2. Support for user-specified encodings in a few specific places
(primarily those related to FreeType).
There certainly isn't any explicit support for right-to-left
languages. Also, any code which uses the curses library will only work
correctly with unibyte encodings (e.g. ISO-8859-*), and not with
multibyte encodings such as UTF-8.
