[GRASS-dev] GUI platforms
Radim Blazek
radim.blazek at gmail.com
Tue May 23 03:18:00 EDT 2006
On 5/23/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > I assume that you can't issue Unix commands in that environment.
> Using the Qgis internal Grass shell you can.
The version for Windows is using MSYS terminal+bash not
the built-in shell. Of course it is possible to run GRASS modules
+ cca 60 standard UNIX commands (sed, gawk, grep, ....)
Radim
> http://mpa.itc.it/radim/wingrass/ says:
> > GRASS scripts works both from GRASS tools and shell
> Propably thanks to Msys http://www.mingw.org/msys.shtml. ?
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
