[GRASS-dev] GUI platforms
Michael Barton
michael.barton at asu.edu
Tue May 23 10:15:55 EDT 2006
Thanks for the clarification.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Radim Blazek <radim.blazek at gmail.com>
> Date: Tue, 23 May 2006 09:18:00 +0200
> To: Maciek Sieczka <werchowyna at epf.pl>
> Cc: Michael Barton <michael.barton at asu.edu>, <twiens at interbaun.com>,
> <david.p.finlayson at gmail.com>, <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] GUI platforms
> On 5/23/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
>>> I assume that you can't issue Unix commands in that environment.
>> Using the Qgis internal Grass shell you can.
> The version for Windows is using MSYS terminal+bash not
> the built-in shell. Of course it is possible to run GRASS modules
> + cca 60 standard UNIX commands (sed, gawk, grep, ....)
> Radim
>> http://mpa.itc.it/radim/wingrass/ says:
>>> GRASS scripts works both from GRASS tools and shell
>> Propably thanks to Msys http://www.mingw.org/msys.shtml. ?
>> Maciek
>> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko
>> najlepsze z nich!
>> http://katalog.panoramainternetu.pl/
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
