[GRASS-dev] GUI platforms
David Finlayson david.p.finlayson at gmail.com
Tue May 23 03:16:39 EDT 2006
Is the goal to eliminate the GRASS dependency on a Unix environment?
To me, that sounds like throwing the baby out with the bath water.
Why not just merge with Qgis?
David
On 5/22/06, Michael Barton <michael.barton at asu.edu> wrote:
> True.
> However, you need a way of communicating with the OS. And a repeated request
> is to maintain a CLI for such communication. Hence, there needs to be a
> terminal-like interface built into the the GUI where commands can be issued.
> A further complicating factor is running GRASS under Windows. Even though
> I'm not a big Windows fan, a LOT of people use this platform. It would be
> great if GRASS could run in Window without the Cygwin emulator. There is a
> version in development now that compiles under MinGW to create a
> 'Windows-native' GRASS. I assume that you can't issue Unix commands in that
> environment. But you should be able to issue commands for Windows versions
> of scripting languages like Python.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: David Finlayson <david.p.finlayson at gmail.com>
> > Date: Mon, 22 May 2006 22:34:36 -0700
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: Trevor Wiens <twiens at interbaun.com>, grass developers list
> > <grass-dev at grass.itc.it>
> > Subject: Re: [GRASS-dev] GUI platforms
> >>> 2. Provide a CLI interface for GRASS program modules
> >> Do we need to drop bash? If so a lot of existing modules and add on's
> >> will go away or need to be ported for 6.3. Or do we envision providing
> >> something like a language based shell (eg Python) as well as bash for
> >> 6.3 to allow for transition and dropping shell programming for 6.4 or
> >> 6.5 (I now way out in the future, but worth thinking about so we don't
> >> make short term decisions that limit that vision).
> > GRASS doesn't just depend on an X11 display; it depends on Unix. You
> > can't remove the Unix part and still have GRASS. Unix permiates GRASS
> > to the core. The GUI should make it easier to use GRASS and Unix not
> > try to replace it.
David Finlayson
