[GRASS-dev] GUI platforms
Glynn Clements
glynn at gclements.plus.com
Tue May 23 05:07:19 EDT 2006
David Finlayson wrote:
> Is the goal to eliminate the GRASS dependency on a Unix environment?
Yes. GRASS should also work on Windows (with neither Cygwin nor an X
server) and MacOSX (without an X server) as well as it does on Unix.
> To me, that sounds like throwing the baby out with the bath water.
Nothing is getting "thrown out".
