[GRASS-dev] move d.vect's test_bg_color() to verbose mode?
Martin Landa
landa.martin at gmail.com
Tue May 23 03:40:54 EDT 2006
2006/5/22, Hamish <hamish_nospam at yahoo.com>:
Hamish,
I agree with you, I hope that the attached patch is acceptable... I
think the better way is to move this warning to verbose mode.
Best regards,
Martin
> If color=white for fcolor=white, d.vect gives
> WARNING: Line color and background color are the same!
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/display/d.vect/main.c.diff?r1=1.58&r2=1.59
> But when plotting over a raster or different d.erase color, this warning
> is superfluous. Should it be changed to only make noise in -v verbose
> mode? (or G_debug(1,))
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060523/79d2b4c1/d_vect_test_background-2006-05-23.diff.gz
