[GRASS-dev] g-ps.map
Moritz Lennert
mlennert at club.worldonline.be
Tue May 23 08:39:44 EDT 2006
Jachym Cepicky wrote:
> Hallo,
> my fault. Bugfix release can be found at
> http://les-ejk.cz/programs/grass/gpsmap-0.1.1.tgz
Now, I can save and print, so basic functionality seems to work !
Some more remarks:
- would be nice to have a "save as..." to be able to change an existing
file and save it under another name
- when I click on 'new' to create a new file, 'save' does not allow me
to chose a new name, but just saves under the previously used name.
- the save dialog says "open" on the button, this should probably be "save"
- When I use vlegend, without filling in the "where" field and then
click on refresh, I get:
File "./gpsmap.py", line 270, in on_refreshButton_clicked
self.draw(None, None)
File "./gpsmap.py", line 450, in draw
(x,y) = string.split(where)
ValueError: unpack list of wrong size
- Similar with a text:
File "./gpsmap.py", line 416, in draw
x,y = self.drawingmap.region2pixel(x,y)
File "/home/jachym/prog/cvs/gpsmap/Modules/drawingMap.py", line 207,
in region2pixel
ValueError: empty string for float()
- However, refresh in any case doesn't do anything. What is it supposed
to do ? When I look at your screenshot, you seem to have placeholders of
the different elements visible. I only see this here, and it doesn't
change, whatever I do:
http://moritz.homelinux.org/grass/gpsmap.png
Don't have time for more at the moment, but I hope this will already be
useful.
Moritz
> thank you for help!
> jachym
> On Fri, May 19, 2006 at 12:44:42AM +0200, Moritz Lennert wrote:
>> Dear Jachym,
>>> GRASS developers and users,
>>> a month ago, when I was learing python, I tryed to write small
>>> application, which should be able to produce configuration file for
>>> ps.map. I called it G-ps.map.
>> Great initiative !
>>> Are there some voluteers, who would like to help with the development?
>>> Lot's of work has to be done. I'm working on some other project now, so
>>> if somebody would help, it would be good.
>> At the moment I really have no time, but I did try to test your program.
>> However, I don't seem to get it to work
>> When I try to save the file, I get:
>> File "SRC/GRASS/gpsmap-0.1/gpsmap.py", line 224, in on_buttonSave_clicked
>> self.on_printMapfile_clicked(self,output=self.psmapfile)
>> File "SRC/GRASS/gpsmap-0.1/gpsmap.py", line 135, in
>> print """
>> TypeError: float argument required
>> When I click on the print button, I get:
>> File "SRC/GRASS/gpsmap-0.1/gpsmap.py", line 155, in
>> instructionKeys, instructionVals =\
>> AttributeError: InstructionsView instance has no attribute 'get_instruction'
>> And with the refresh button, I get this:
>> File "SRC/GRASS/gpsmap-0.1/gpsmap.py", line 270, in
>> File "SRC/GRASS/gpsmap-0.1/gpsmap.py", line 466, in draw
>> x,y = self.drawingmap.region2pixel(string.atof(x),\
>> File "/usr/lib/python2.3/string.py", line 205, in atof
>> return _float(s)
>> ValueError: invalid literal for float(): x
>> For your information, I use Debian, with the following packages:
>> python 2.3.5
>> python-glade2 2.8.2
>> python-gtk 2.8.2
>> and CVS-tree GRASS.
>> Moritz
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
