[GRASS-dev] Re: [GRASS-QA] SOCCER LAB GRASS QA: 12 clones (
anim_support.c ) 0 monsters and 0 warnings
Markus Neteler
neteler at itc.it
Thu May 25 14:11:10 EDT 2006
(for those not aware of the GRASS-QA service)
there seems to be some cloned code here, see at bottom.
Markus
On Thu, May 25, 2006 at 01:35:30PM -0400, cvs at proxy.soccerlab.polymtl.ca wrote:
> ANALYSIS
> your changes to files/functions:
> visualization/nviz/src/anim_support.c functions
> Nset_interp_mode_cmd (Begins at: 32 Ends at: 74)
> Complexity: | 4 | | OK |
> ParamNBR: | 4 | | OK |
> CalledNBR: | 3 | | OK |
> LOC: | 43 | | OK |
> metrics are OK
> Nset_tension_cmd (Begins at: 76 Ends at: 121)
> CalledNBR: | 2 | | OK |
> LOC: | 46 | | OK |
> metrics are OK
> Nshowtension_start_cmd (Begins at: 123 Ends at: 140)
> Complexity: | 2 | | OK |
> CalledNBR: | 1 | | OK |
> LOC: | 18 | | OK |
> metrics are OK
> Nupdate_tension_cmd (Begins at: 142 Ends at: 159)
> LOC: | 18 | | OK |
> metrics are OK
> Nshowtension_stop_cmd (Begins at: 161 Ends at: 195)
> LOC: | 35 | | OK |
> metrics are OK
> Nupdate_frames_cmd (Begins at: 197 Ends at: 230)
> LOC: | 34 | | OK |
> metrics are OK
> Nset_numsteps_cmd (Begins at: 232 Ends at: 268)
> Complexity: | 3 | | OK |
> LOC: | 37 | | OK |
> metrics are OK
> Nclear_keys_cmd (Begins at: 270 Ends at: 338)
> LOC: | 69 | | OK |
> metrics are OK
> Nadd_key_cmd (Begins at: 340 Ends at: 437)
> Complexity: | 17 | * | |
> CalledNBR: | 19 | | OK |
> LOC: | 98 | | OK |
> metrics are OK
> Ndelete_key_cmd (Begins at: 439 Ends at: 486)
> Complexity: | 5 | | OK |
> CalledNBR: | 5 | | OK |
> LOC: | 48 | | OK |
> metrics are OK
> Nmove_key_cmd (Begins at: 488 Ends at: 537)
> CalledNBR: | 7 | | OK |
> LOC: | 50 | | OK |
> metrics are OK
> Ndo_framestep_cmd (Begins at: 539 Ends at: 580)
> LOC: | 42 | | OK |
> metrics are OK
> Nshow_site_cmd (Begins at: 582 Ends at: 605)
> LOC: | 24 | | OK |
> metrics are OK
> Nprint_keys_cmd (Begins at: 607 Ends at: 624)
> LOC: | 18 | | OK |
> metrics are OK
> Nshow_vect_cmd (Begins at: 626 Ends at: 649)
> LOC: | 24 | | OK |
> metrics are OK
> Nshow_vol_cmd (Begins at: 651 Ends at: 674)
> LOC: | 24 | | OK |
> metrics are OK
> Nshow_lab_cmd (Begins at: 676 Ends at: 699)
> LOC: | 24 | | OK |
> metrics are OK
> Nshow_path_cmd (Begins at: 702 Ends at: 739)
> LOC: | 38 | | OK |
> metrics are OK
> Nwrite_rgb_cmd (Begins at: 741 Ends at: 772)
> LOC: | 32 | | OK |
> metrics are OK
> Nwrite_ppm_cmd (Begins at: 774 Ends at: 805)
> LOC: | 32 | | OK |
> metrics are OK
> Nwrite_tif_cmd (Begins at: 807 Ends at: 824)
> LOC: | 18 | | OK |
> metrics are OK
> Noff_screen_cmd (Begins at: 827 Ends at: 863)
> CalledNBR: | 4 | | OK |
> LOC: | 37 | | OK |
> metrics are OK
> Ninit_mpeg_cmd (Begins at: 869 Ends at: 889)
> LOC: | 21 | | OK |
> metrics are OK
> Nwrite_mpeg_frame_cmd (Begins at: 894 Ends at: 911)
> LOC: | 18 | | OK |
> metrics are OK
> Nclose_mpeg_cmd (Begins at: 916 Ends at: 933)
> LOC: | 18 | | OK |
> metrics are OK
> Clone analysis:
> This file has 12 potentially cloned functions:
> Nclose_mpeg_cmd Nwrite_mpeg_frame_cmd Nwrite_tif_cmd Nprint_keys_cmd Nupdate_tension_cmd Nshowtension_start_cmd Nshow_lab_cmd Nshow_vol_cmd Nshow_vect_cmd Nshow_site_cmd Nwrite_ppm_cmd Nwrite_rgb_cmd
> In visualization/nviz/src/anim_support.c clones of Nshow_vol_cmd are:
> visualization/nviz/src/anim_support.c Nshow_lab_cmd
> visualization/nviz/src/anim_support.c Nshow_vect_cmd
> visualization/nviz/src/anim_support.c Nshow_site_cmd
> In visualization/nviz/src/anim_support.c clones of Nclose_mpeg_cmd are:
> visualization/nviz/src/anim_support.c Nwrite_mpeg_frame_cmd
> visualization/nviz/src/anim_support.c Nwrite_tif_cmd
> visualization/nviz/src/anim_support.c Nprint_keys_cmd
> visualization/nviz/src/anim_support.c Nupdate_tension_cmd
> visualization/nviz/src/anim_support.c Nshowtension_start_cmd
> In visualization/nviz/src/anim_support.c clones of Nwrite_tif_cmd are:
> visualization/nviz/src/anim_support.c Nclose_mpeg_cmd
> In visualization/nviz/src/anim_support.c clones of Nwrite_ppm_cmd are:
> visualization/nviz/src/anim_support.c Nwrite_rgb_cmd
> In visualization/nviz/src/anim_support.c clones of Nwrite_rgb_cmd are:
> visualization/nviz/src/anim_support.c Nwrite_ppm_cmd
> In visualization/nviz/src/anim_support.c clones of Nprint_keys_cmd are:
> In visualization/nviz/src/anim_support.c clones of Nshow_lab_cmd are:
> visualization/nviz/src/anim_support.c Nshow_vol_cmd
> In visualization/nviz/src/anim_support.c clones of Nshow_vect_cmd are:
> In visualization/nviz/src/anim_support.c clones of Nupdate_tension_cmd are:
> In visualization/nviz/src/anim_support.c clones of Nshow_site_cmd are:
> In visualization/nviz/src/anim_support.c clones of Nshowtension_start_cmd are:
> In visualization/nviz/src/anim_support.c clones of Nwrite_mpeg_frame_cmd are:
> __________________________________________
> Threshold GRASS6 key metrics values at 2006-05-25 are:
> median | upper | outlier |
> | quartile | limit |
> Complexity (Cyclo): 5 | 25 | 36 |
> ParamNBR: 2 | 6 | 8 |
> CalledNBR: 9 | 55 | 79 |
> LOC: 40 | 182 | 253 |
> Measures (see below Web page for details):
> Complexity (Cyclo): a complexity index
> ParamNBR: number of passed parameters
> CalledNBR: number of called functions
> LOC: Lines Of Code
> Message interpretation:
> OK : Nothing to say at all
> * : above 75 % of value warning
> ** : this is getting close to be out of range, consider revising the code
> ***: this is a monster, definitely you should revise this function
> Brought to you by:
> SOftware Cost-effective Change and Evolution Research (SOCCER) laboratory
> http://web.soccerlab.polymtl.ca/grass-evolution/grass-browsers/grass-index-en.html
> grass-qa mailing list
> grass-qa at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-qa
