[GRASS-dev] Wiki: GRASS compile howto updated
Sun May 28 19:19:19 EDT 2006
Yann Chemin wrote:
> Maybe a newbie note, but it may help for comprehension.
> For --with-glw, which software homepage to look for?
The --with-glw option no longer has any use. It used to be required
for r3.showdspf, but that module is no longer built regardless of
configure switches. AFAIK, it has been made obsolete by recent version
of NVIZ.
FWIW, there are two implementations of the GLw library, from:
	http://www.x.org/	(part of X11)
or:
	http://www.mesa3d.org/	(part of Mesa)
> and similarly for non-obvious configure options.
Other libraries which may be used but which aren't documented in
REQUIREMENTS.html are:
FFMPEG:		http://ffmpeg.sourceforge.net/index.php
OpenDWG:	http://www.opendesign.com/
