[GRASS-dev] GUI toolkits
David Finlayson
david.p.finlayson at gmail.com
Sun May 28 23:53:35 EDT 2006
I think that many of us are excited about the Python SWIG interface to
the GRASS API because it affords us the opportunity to write entirely
new modules using a higher-level language than C. These new programs
should obey all the standard GRASS conventions for an independent
program.
If a new GUI is developed using Python + GUI toolkit, that is a
separate issue. Python shouldn't have any problems with a complicated
GUI, but there are apparently limits to its performance. I noticed
that Scribus, a sophisticated drawing program that was originally
developed using only Python has switched to QT (C++) for performance
reasons. I wasn't able to find a document describing what the
performance problems were with Python.
Scribus and a future GUI for GRASS would have similar designs. Maybe
someone should contact the Scribus developers and find out what the
limitations were with Python + GUI toolkit?
David
On 5/28/06, Hamish <hamish_nospam at yahoo.com> wrote:
> > > 2. GRASS is primarily written in C so if we want to use a compiled
> > > language, C would be the natural choice.
> > This is only relevant if the GUI actually links to GRASS libraries,
> > which isn't necessarily a good idea. The design of the GRASS libraries
> > doesn't really lend itself to persistent applications.
> does this mean that Python + SWIG is a bad idea?
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
David Finlayson
