[GRASS-dev] GUI toolkits
Glynn Clements
glynn at gclements.plus.com
Mon May 29 09:29:41 EDT 2006
Hamish wrote:
> > > 2. GRASS is primarily written in C so if we want to use a compiled
> > > language, C would be the natural choice.
> > This is only relevant if the GUI actually links to GRASS libraries,
> > which isn't necessarily a good idea. The design of the GRASS libraries
> > doesn't really lend itself to persistent applications.
> does this mean that Python + SWIG is a bad idea?
Not in itself.
It's using the GRASS libraries from within a GUI which is problematic.
Writing a GUI using Python and other libraries isn't an issue. Writing
GRASS modules using Python and the GRASS libraries isn't an issue
either.
