[GRASS-dev] Areas
Maciek Sieczka
werchowyna at epf.pl
Mon May 29 15:46:47 EDT 2006
On Mon, 29 May 2006 13:40:55 +0300 (EEST)
Wolf Bergenheim <wolf+grass at bergenheim.net> wrote:
> Hi!
> When starting to think about areas I played with v.digit a bit, and
> it seems that it creates different cat for the boundary and centroid.
Only if you request it. You can digitize a boundary (any other feature
too) without category. Or with any cat you specify manually, eg. if you
want to attach the new feature to an existant datatable entry.
> Is this what we want? I've always thought of them as kind of bound
> together, and thus would expect them to have the same cat.
> Am Itotally off base here? What about islands? Should they have a cat
> at all, or should they have the same cat as the area that they belong
> to? Or something totally different?
When digitising adjacent areas (sharing a common border line),
categories for boundaries are redundant, if not a disturbance. We
only need cats for centroids then. This also solves the problem of
islands. When the island boundary doesn't have a cat attached,
attributes belong only to centroids in the surroning areas - and no
problem.
That's at least the way I see it.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
