[GRASS-dev] HDF5 datasets and georeferencing
Tue May 30 13:07:28 EDT 2006
Stephan Holl wrote:
> Dear List,
> I have a HDF5-image with several subdataset. Accroding to gdalinfo it
> is projected in epsg:4326 (lon/lat) but the corner-coords seem not to
> represent the correct corrdinates. Therefor GRASS complains during import.
Stephan,
Can you make your hdf5 dataset available for review?  I suspect there is
some sort of WGS84 geolocation in the file that isn't being returned.
There *might* be something that can be done about it.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
