[GRASS-dev] Discussing new GUI toolkit: v.pydigit
William Kyngesburye woklist at kyngchaos.com
Wed May 31 10:26:29 EDT 2006
On May 31, 2006, at 7:19 AM, Jachym Cepicky wrote:
>> We should try and keep things easy to use for people with Mac OSX on
>> laptops (only one mouse button). Annoying, but in the end you get a
>> simpler to use app for new users. IIRC, one of the main reasons
>> the mac
>> stayed with the one button setup is that it forces devels to work
>> harder
>> on their design which leads to better experience for the end user.
> I can see your point. How is it done? Really only by mouse or can you
> use key strokes (Ctrl..) too?
> Suggestion:
>     mouseL 1 click - digitize
>     mouseL dbl click - menu
>                         |-> End digitizing
>                         |-> Delete last
>                         |-> Delete all
>                         |-> Snap to closesd node
>                         if boundary -> snap to begin
>    mouseR - end digitizing
>    mouseM - Delete last
I wonder - does it (python I assume you mean here) get button-click
info from the system, or interpret mouse/trackpad directly?  A
feature of recent PowerBooks, and the new MacBook I'm lovin', is (if
one uses the pad-tap feature) tapping with *two* fingers does a right-
click.  If Python sees it as left/right click, you wouldn't have to
worry about trying to interpret meta-keys as well.  Same goes for
ctrl-click - it's a standard setup for the system to do a right-click
- if Python sees this as right-click instead of ctrl-click, it
wouldn't have to deal with having to have alternatives for extra
buttons on a Mac.  There's nothing for a middle-click, so we're only
down to two buttons, not one.
There are also drivers available to do similar things for older
PowerBooks.
>> Will development of the GUI on a Mac require a Fink install? (e.g.
>> glade2)
> What is Fink?
Fink is just *one* way to get Unix libraries and programs on Mac OS
X.  It's a package manager.  Another is Darwinports.  Personally I
don't use either.  Many don't.  I would build my own dependencies
needed or locate a binary distribution.  Mac Python extensions have
their own binary distribution repository anyways (though it's kinda
lean right now, as the Universal Python 2.4.3 is so new, but wxPython
is there).
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
