[GRASS-dev] Discussing new GUI toolkit: v.pydigit
Jachym Cepicky
jachym.cepicky at centrum.cz
Wed May 31 08:19:07 EDT 2006
Hallo,
On Wed, May 31, 2006 at 09:56:17PM +1200, Hamish wrote:
> FWIW, I don't know any Python, but I could learn some. (Transferable
> skills are nice)
it is easy to learn -> basics took me about a week
> > v.pydigit should be graphical frontend to v.edit.
> > Known problems:
> > * Data reading/writing: Currently, the data are read through
> > v.out.ascii and the output (new data storing) is made by
> > v.edit
> > Sollution: Swig? OGR?
> what about "v.in.ascii format=standard" and v.patch?
> for raster option use r.in.poly or "v.in.*/v.edit" + v.to.rast?
He? Do you mean, that v.pydigit could be used as r.digit?
> > * Raster map display.
> > Sollution: Swig? GDAL? r.out.png?
> Same as gis.m? Use the PNG driver to make a PNG (smaller file) or PPM
> (faster) image. Zoom/pan by setting "soft" region changes with
> GRASS_REGION= enviro variable?? (then GUI must keep track)
Currently: GRASS region settings are not touched. The script reads them
(g.region -g) and stores to self.region dictionary
(Vpydigit/vdigitGui.py). Everytime, it is zoomed/paned, this variable is
changed.
I wanted to do it possible independent on the Xdriver - didn't we want
to get rid of it?
Personally I thing, that the Zoom->PPM->Display approach one of the
reasons is, why *some* people od not really like the new gis.m - it is
slow. But I can see, there is no better way yet (swig could do this job IMHO).
I was thinking about not to produce one big raster file, but to perform
kind of tiling support - but maybe later. If there would be quadtree
support in GRASS-rasters, would this problem allready be solved(?).
> see: g.manual pngdriver
I'll
> > Screenshots:
> > http://les-ejk.cz/tmp/vpydigit1.png
> > http://les-ejk.cz/tmp/vpydigit2.png
> nice.
> other points:
> which of the toolkits has the best support for translation efforts?
AFAIK Qt and Gtk both. wxWindows?
> We should try and keep things easy to use for people with Mac OSX on
> laptops (only one mouse button). Annoying, but in the end you get a
> simpler to use app for new users. IIRC, one of the main reasons the mac
> stayed with the one button setup is that it forces devels to work harder
> on their design which leads to better experience for the end user.
I can see your point. How is it done? Really only by mouse or can you
use key strokes (Ctrl..) too?
Suggestion:
mouseL 1 click - digitize
mouseL dbl click - menu
|-> End digitizing
|-> Delete last
|-> Delete all
|-> Snap to closesd node
if boundary -> snap to begin
mouseR - end digitizing
mouseM - Delete last
> Will development of the GUI on a Mac require a Fink install? (e.g. glade2)
What is Fink?
> Will the toolkit create a "native" looking/acting application? (yes please)
AFAIK now. Does it harm? Mac people: could you live with gui like this?
> Glade makes XML files from a GUI.. how does Python fit in?
Python takes the xml and generates the gui on-the-fly. You are only
writing the handlers.
> Hamish
Thank you for your feedback and help
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060531/30a87a4b/attachment.bin
