[GRASS-dev] random colors in d.vect
Huidae Cho
grass4u at gmail.com
Wed May 31 11:53:22 EDT 2006
What's different between 'd.vect -c' and your patch? The -c flag also
implements random colors based on category/layer number.
Huidae Cho
On Wed, May 31, 2006 at 11:36:10AM +0200, Martin Landa wrote:
> Hi all,
> I have tried to implement *random* colouring based on category number
> (according to layer number can be implemented later before CVS
> committing...), see the attached patch.
> I do not completely understand why you need to use in level 2
> Vect_line_alive() + Vect_read_line() in contrast with level 1 and
> function Vect_read_next_line (). In any case the functions
> Vect_read_line () and Vect_read_next_line behave in the same way -
> they may return 'line number', -1 or -2. So I do not know why
> variable 'ltype' is tested only (switch (ltype)) in level 1.
> Best regards, Martin
> PS: Temporarily I have no GNU/Linux PC with Internet connection, so
> this patch is against CVS snapshot from 2006/05/27.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
