[GRASS-dev] random colors in d.vect
Martin Landa landa.martin at gmail.com
Wed May 31 13:40:45 EDT 2006
the difference is that the current implementation use 'pseudo random'
colors (e.g. cat % palette_ncolors), i.e. the color composition is
always the same. The patch changes this behaviour, it means, you will
not get the same colours by d.vect -c (it is useful if you do not like
the current colors).
Best, Martin
2006/5/31, Huidae Cho <grass4u at gmail.com>:
> Hi,
> What's different between 'd.vect -c' and your patch?  The -c flag also
> implements random colors based on category/layer number.
> Huidae Cho
> On Wed, May 31, 2006 at 11:36:10AM +0200, Martin Landa wrote:
> > Hi all,
> > I have tried to implement *random* colouring based on category number
> > (according to layer number can be implemented later before CVS
> > committing...), see the attached patch.
> > I do not completely understand why you need to use in level 2
> > Vect_line_alive() + Vect_read_line() in contrast with level 1 and
> > function Vect_read_next_line (). In any case the functions
> > Vect_read_line () and Vect_read_next_line behave in the same way -
> > they may return 'line number', -1 or -2. So I do not know why
> > variable 'ltype' is tested only (switch (ltype)) in level 1.
> > Best regards, Martin
> > PS: Temporarily I have no GNU/Linux PC with Internet connection, so
> > this patch is against CVS snapshot from 2006/05/27.
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
