FW: [GRASS-dev] NVIZ problem on Intel Macs
Wed May 31 21:06:09 EDT 2006
Michael Barton wrote:
> See Glynn's response below. I'm wondering if perhaps you need to install a
> new version of x11?? Or maybe get a new version of OpenGL?? to go with the
> Intel Macs
If anything, you might need to use an older version.
Apparently, GLX support on MacOSX has been broken since X11R6.9:
http://lists.freedesktop.org/archives/xorg/2006-May/015716.html
"Broken" in the sense of compile errors in the DRI code, so presumably
any precompiled X servers for OSX which are newer than that will have
DRI support disabled.
Also, using:
	export LIBGL_ALWAYS_INDIRECT=1
may eliminate the error.
