[GRASS-dev] call for last minute testers
Otto Dassau
otto.dassau at gmx.de
Wed Nov 1 03:32:44 EST 2006
On Tue, 31 Oct 2006 12:18:38 -0700
Michael Barton <michael.barton at asu.edu> wrote:
> Otto,
> I had sent in the wrong version of a georectifier update last night. I sent
> in a new one this morning to Markus, who put it into 6.2. I just added it to
> 6.3 a moment ago. I don't know if this fixes the problem you are having, but
> you might test it. Thanks for the info.
Hi Michael,
Thanks for the fix. I just tested it with the new snapshot from
http://grass.itc.it/grass62/source/snapshot/ but with the same error.
And another problem occurs. I am not able to create/edit a group anymore. The
second button only works for vector rectification but not for raster.
regards,
Otto
> Michale
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Otto Dassau <otto.dassau at gmx.de>
> > Date: Tue, 31 Oct 2006 14:05:13 +0100
> > To: <grass-dev at grass.itc.it>
> > Subject: Re: [GRASS-dev] call for last minute testers
> > On Tue, 31 Oct 2006 23:40:13 +1300
> > Hamish <hamish_nospam at yahoo.com> wrote:
> >> Hi,
> >> Michael & myself have just applied some last minute patches to gis.m to
> >> make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
> >> without much (any) testing, if everyone could quickly update gis.m in
> >> their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
> >> make, and double check that we haven't broken anything? (main toolbar
> >> and the georectifyer canvas toolbar)
> > Hi,
> > using the "clear all GPC entries" button (in the georectifyer) after setting
> > various GCPs only clears the first 2 columns of the first line, but the
> > forward
> > and backward errors remain with following error message (command name below
> > is the RMS error in line 1 third col):
> > invalid command name "0.590568"
> > while executing
> > "$fwd_error($gcpnum) delete 0 end"
> > (procedure "GRMap::cleargcp" line 14)
> > invoked from within
> > "GRMap::cleargcp"
> > ("uplevel" body line 1)
> > invoked from within
> > "uplevel \#0 $cmd"
> > (procedure "Button::_release" line 18)
> > invoked from within
> > "Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
> > (command bound to event
> > I tested with the 6.2 snapshot. Maybe someone can reproduce this?
> > regards,
> > Otto
> >> thanks a lot,
> >> Hamish
