[GRASS-dev] call for last minute testers
Otto Dassau
otto.dassau at gmx.de
Wed Nov 1 04:58:48 EST 2006
On Wed, 1 Nov 2006 09:32:44 +0100
Otto Dassau <otto.dassau at gmx.de> wrote:
> On Tue, 31 Oct 2006 12:18:38 -0700
> Michael Barton <michael.barton at asu.edu> wrote:
> > Otto,
> > I had sent in the wrong version of a georectifier update last night. I sent
> > in a new one this morning to Markus, who put it into 6.2. I just added it to
> > 6.3 a moment ago. I don't know if this fixes the problem you are having, but
> > you might test it. Thanks for the info.
> Hi Michael,
> Thanks for the fix. I just tested it with the new snapshot from
> http://grass.itc.it/grass62/source/snapshot/ but with the same error.
> And another problem occurs. I am not able to create/edit a group anymore. The
> second button only works for vector rectification but not for raster.
I also compiled grass-6.2.0.tar.gz but get the same error as with the latest
6.2 snapshot.
regards,
Otto
> regards,
> Otto
> > Michale
> > __________________________________________
> > Michael Barton, Professor of Anthropology
> > School of Human Evolution & Social Change
> > Center for Social Dynamics and Complexity
> > Arizona State University
> > phone: 480-965-6213
> > fax: 480-965-7671
> > www: http://www.public.asu.edu/~cmbarton
> > > From: Otto Dassau <otto.dassau at gmx.de>
> > > Date: Tue, 31 Oct 2006 14:05:13 +0100
> > > To: <grass-dev at grass.itc.it>
> > > Subject: Re: [GRASS-dev] call for last minute testers
> > > On Tue, 31 Oct 2006 23:40:13 +1300
> > > Hamish <hamish_nospam at yahoo.com> wrote:
> > >> Hi,
> > >> Michael & myself have just applied some last minute patches to gis.m to
> > >> make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
> > >> without much (any) testing, if everyone could quickly update gis.m in
> > >> their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
> > >> make, and double check that we haven't broken anything? (main toolbar
> > >> and the georectifyer canvas toolbar)
> > > Hi,
> > > using the "clear all GPC entries" button (in the georectifyer) after
setting
> > > various GCPs only clears the first 2 columns of the first line, but the
> > > forward
> > > and backward errors remain with following error message (command name
below
> > > is the RMS error in line 1 third col):
> > > invalid command name "0.590568"
> > > while executing
> > > "$fwd_error($gcpnum) delete 0 end"
> > > (procedure "GRMap::cleargcp" line 14)
> > > invoked from within
> > > "GRMap::cleargcp"
> > > ("uplevel" body line 1)
> > > invoked from within
> > > "uplevel \#0 $cmd"
> > > (procedure "Button::_release" line 18)
> > > invoked from within
> > > "Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
> > > (command bound to event
> > > I tested with the 6.2 snapshot. Maybe someone can reproduce this?
> > > regards,
> > > Otto
> > >> thanks a lot,
> > >> Hamish
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
