[GRASS-dev] georectifier fixes
Michael Barton
michael.barton at asu.edu
Wed Nov 1 13:38:19 EST 2006
I just committed a set of fixes to the georectifier. This should fix all
reported bugs. (can't speak for new ones, but hopefully there aren't any).
Please test.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Otto Dassau <otto.dassau at gmx.de>
> Date: Wed, 1 Nov 2006 16:09:09 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS-dev] call for last minute testers
> On Wed, 01 Nov 2006 07:53:09 -0700
> Michael Barton <michael.barton at asu.edu> wrote:
>> Thanks. I'll check it out. You can always edit a group by running i.group
>> from the xy location, but it ought to work from the georectifier.
> thanks a lot!
> Otto
>> Michael
>> Center for Social Dynamics & Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Wed, 1 Nov 2006 09:32:44 +0100
>>> Cc: <grass-dev at grass.itc.it>
>>> On Tue, 31 Oct 2006 12:18:38 -0700
>>>> Otto,
>>>> I had sent in the wrong version of a georectifier update last night. I sent
>>>> in a new one this morning to Markus, who put it into 6.2. I just added it
> to
>>>> 6.3 a moment ago. I don't know if this fixes the problem you are having,
> but
>>>> you might test it. Thanks for the info.
>>> Hi Michael,
>>> Thanks for the fix. I just tested it with the new snapshot from
>>> http://grass.itc.it/grass62/source/snapshot/ but with the same error.
>>> And another problem occurs. I am not able to create/edit a group anymore.
> The
>>> second button only works for vector rectification but not for raster.
>>> regards,
>>> Otto
>>>> Michale
>>>> phone: 480-965-6213
>>>> fax: 480-965-7671
>>>>> Date: Tue, 31 Oct 2006 14:05:13 +0100
>>>>> To: <grass-dev at grass.itc.it>
>>>>> On Tue, 31 Oct 2006 23:40:13 +1300
>>>>> Hamish <hamish_nospam at yahoo.com> wrote:
>>>>>> Hi,
>>>>>> Michael & myself have just applied some last minute patches to gis.m to
>>>>>> make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
>>>>>> without much (any) testing, if everyone could quickly update gis.m in
>>>>>> their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
>>>>>> make, and double check that we haven't broken anything? (main toolbar
>>>>>> and the georectifyer canvas toolbar)
>>>>> Hi,
>>>>> using the "clear all GPC entries" button (in the georectifyer) after
> setting
>>>>> various GCPs only clears the first 2 columns of the first line, but the
>>>>> forward
>>>>> and backward errors remain with following error message (command name
> below
>>>>> is the RMS error in line 1 third col):
>>>>> invalid command name "0.590568"
>>>>> while executing
>>>>> "$fwd_error($gcpnum) delete 0 end"
>>>>> (procedure "GRMap::cleargcp" line 14)
>>>>> invoked from within
>>>>> "GRMap::cleargcp"
>>>>> ("uplevel" body line 1)
>>>>> invoked from within
>>>>> "uplevel \#0 $cmd"
>>>>> (procedure "Button::_release" line 18)
>>>>> invoked from within
>>>>> "Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
>>>>> (command bound to event
>>>>> I tested with the 6.2 snapshot. Maybe someone can reproduce this?
>>>>> regards,
>>>>> Otto
>>>>>> thanks a lot,
>>>>>> Hamish
