[GRASS-dev] Re: georectifier fixes
Otto Dassau
otto.dassau at gmx.de
Wed Nov 1 14:20:21 EST 2006
On Wed, 01 Nov 2006 11:38:19 -0700
Michael Barton <michael.barton at asu.edu> wrote:
> I just committed a set of fixes to the georectifier. This should fix all
> reported bugs. (can't speak for new ones, but hopefully there aren't any).
> Please test.
the "clear all GPC entries" button is working now - thanks a lot!
It deletes all entries. Would it be possible that it depends on wether a GCP is
used (selected) or not? I think that would be useful, after choosing the best
GCPs I could delete the rest very easily.
The second error still exists. The create/edit a group button doesn't work.
kind regards,
Otto
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Otto Dassau <otto.dassau at gmx.de>
> > Date: Wed, 1 Nov 2006 16:09:09 +0100
> > To: Michael Barton <michael.barton at asu.edu>
> > Subject: Re: [GRASS-dev] call for last minute testers
> > On Wed, 01 Nov 2006 07:53:09 -0700
> >> Thanks. I'll check it out. You can always edit a group by running i.group
> >> from the xy location, but it ought to work from the georectifier.
> > thanks a lot!
> > Otto
> >> Michael
> >> Center for Social Dynamics & Complexity
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >>> Date: Wed, 1 Nov 2006 09:32:44 +0100
> >>> Cc: <grass-dev at grass.itc.it>
> >>> On Tue, 31 Oct 2006 12:18:38 -0700
> >>>> Otto,
> >>>> I had sent in the wrong version of a georectifier update last night. I
sent
> >>>> in a new one this morning to Markus, who put it into 6.2. I just added it
> > to
> >>>> 6.3 a moment ago. I don't know if this fixes the problem you are having,
> > but
> >>>> you might test it. Thanks for the info.
> >>> Hi Michael,
> >>> Thanks for the fix. I just tested it with the new snapshot from
> >>> http://grass.itc.it/grass62/source/snapshot/ but with the same error.
> >>> And another problem occurs. I am not able to create/edit a group anymore.
> > The
> >>> second button only works for vector rectification but not for raster.
> >>> regards,
> >>> Otto
> >>>> Michale
> >>>> phone: 480-965-6213
> >>>> fax: 480-965-7671
> >>>>> Date: Tue, 31 Oct 2006 14:05:13 +0100
> >>>>> To: <grass-dev at grass.itc.it>
> >>>>> On Tue, 31 Oct 2006 23:40:13 +1300
> >>>>> Hamish <hamish_nospam at yahoo.com> wrote:
> >>>>>> Hi,
> >>>>>> Michael & myself have just applied some last minute patches to gis.m to
> >>>>>> make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
> >>>>>> without much (any) testing, if everyone could quickly update gis.m in
> >>>>>> their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
> >>>>>> make, and double check that we haven't broken anything? (main toolbar
> >>>>>> and the georectifyer canvas toolbar)
> >>>>> Hi,
> >>>>> using the "clear all GPC entries" button (in the georectifyer) after
> > setting
> >>>>> various GCPs only clears the first 2 columns of the first line, but the
> >>>>> forward
> >>>>> and backward errors remain with following error message (command name
> > below
> >>>>> is the RMS error in line 1 third col):
> >>>>> invalid command name "0.590568"
> >>>>> while executing
> >>>>> "$fwd_error($gcpnum) delete 0 end"
> >>>>> (procedure "GRMap::cleargcp" line 14)
> >>>>> invoked from within
> >>>>> "GRMap::cleargcp"
> >>>>> ("uplevel" body line 1)
> >>>>> invoked from within
> >>>>> "uplevel \#0 $cmd"
> >>>>> (procedure "Button::_release" line 18)
> >>>>> invoked from within
> >>>>> "Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
> >>>>> (command bound to event
> >>>>> I tested with the 6.2 snapshot. Maybe someone can reproduce this?
> >>>>> regards,
> >>>>> Otto
> >>>>>> thanks a lot,
> >>>>>> Hamish
