[GRASS-dev] [bug #5258] (grass) v.patch: crash or ERROR, if tables missing in input
Maciek Sieczka via RT grass-bugs at intevation.de
Sun Nov 5 06:31:35 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5258
hamish_nospam at yahoo.com wrote (Sun, Nov 5 2006 06:45:09):
> Guido Lorenz wrote:
>> v.patch -e input=paguirre2006base4,testarea output=testpatch
>> --overwrite GRASS_INFO_ERROR(28119,1): Missing table
>> Manually creating a database table in PostgreSQL, connecting it to the
>> vector file (v.db.connect) and updloading the cat values is a simple
>> workaround so far.
> v.in.region creates a vector box -- it has no attributes that need
> storing in a table.
The problem is with v.patch. It will not work if used with -e while any of the
input vectors doesn't have a table. I'm renaming the bug.
> I can't comment on PosgreSQL or deriative needs.
This is not related to Postgres. With DBF it's the same.
Moreover, v.patch segfaults if used with -e while *neither* input vector has a
table. See the follwoing examples:
in spearfish60:
$ v.random out=pt1 n=10
$ v.random out=pt2 n=10
### CASE 1: neither input vector has a table:
$ v.patch input=pt1,pt2 out=ptp -e
Segmentation fault (core dumped)
$ gdb v.patch core
(gdb) bt
#0  0x0804a29f in main (argc=0, argv=0xbfcdf604) at main.c:193
(gdb) q
### CASE 2: only one input vector doesn't have a table:
$ v.db.addtable pt1 columns="cat integer"
ERROR: Missing table
### CASE 3: both input vectors have a table:
$ v.db.addtable pt2 columns="cat integer"
(works)
Maciek
-------------------------------------------- Managed by Request Tracker
