[GRASS-dev] [bug #5260] (grass) r.terraflow will not compile
Request Tracker grass-bugs at intevation.de
Sun Nov 5 18:10:26 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5260
Subject: r.terraflow will not compile
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 6.2.0 & latest 6.3 CVS
I could not compile r.terraflow in Fedora Core 6.  Another user had similar error.  See: http://grass.itc.it/pipermail/grass-dev/2006-October/026953.html
I found thread where 5.7 apparently had same or similar problem. I was able to compile by removing <T, Compare> on line 120 in replacementHeap.h and on line 122 in replacementHeapBlock.h  I have not tested it but it does compile without errors after those changes.
Regards,
Floyd
-------------------------------------------- Managed by Request Tracker
