[GRASS-dev] OpenMotif
Brad Douglas
rez at touchofmadness.com
Sun Nov 5 19:27:43 EST 2006
Hello,
It has come to my attention that openmotif is not compatible with the
GRASS license. Most of the functionality has been duplicated in
lesstif, which has a compatible license.
I've been able to successfully compile GRASS using lesstif as a drop-in
replacement.
Should we move GRASS to lesstif? All that really needs to be done is
simply replace text that says openmotif/motif with lesstif (ie.
cosmetics).
Redhat has officially dropped support for openmotif and anything that
won't compile without it as of Fedora Core 6. I assume other vendors
will follow.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
