[GRASS-dev] OpenMotif
Scott Mitchell
smitch at mac.com
Sun Nov 5 22:04:56 EST 2006
On 5 Nov 2006, at 19:27, Brad Douglas wrote:
> Hello,
> It has come to my attention that openmotif is not compatible with the
> GRASS license. Most of the functionality has been duplicated in
> lesstif, which has a compatible license.
> I've been able to successfully compile GRASS using lesstif as a
> drop-in
> replacement.
I've been compiling GRASS against lesstif for years on Linux and
MacOSX, no troubles, although I have only actually used the xanim
program once or twice.
> Should we move GRASS to lesstif? All that really needs to be done is
> simply replace text that says openmotif/motif with lesstif (ie.
> cosmetics).
What text do you mean? REQUIREMENTS.html lists lesstif as the
suggested dependency, and a google search for Motif and GRASS only
finds mailing list discussions and pointers to packages... ah-ha,
that's one place I guess, the rpm spec files... Debian is already
using lesstif. Anything else that I'm missing?
Scott Mitchell
smitch at mac.com
