[GRASS-dev] drop db.droptable man page?
Wed Nov 8 01:47:17 EST 2006
db.droptable's man page still gets generated even though the module has
been removed* from the Makefile.
* rev 1.23:
  http://freegis.org/cgi-bin/viewcvs.cgi/grass6/db/base/Makefile
is this patch correct?
Hamish
Index: db/base/Makefile
RCS file: /home/grass/grassrepository/grass6/db/base/Makefile,v
retrieving revision 1.27
diff -u -r1.27 Makefile
--- db/base/Makefile    22 Sep 2006 16:30:51 -0000      1.27
+++ db/base/Makefile    8 Nov 2006 06:45:30 -0000
@@ -54,6 +54,6 @@
 $(BIN)/db.connect$(EXE): $(OBJDIR)/connect.o
        $(CC) $(LDFLAGS) -o $@ $(OBJDIR)/connect.o $(FMODE_OBJ) $(LIBES) $(XDRLIB) $(MATHLIB)
-#not used: db.createdb db.dropdb db.databases
-PROGRAMS = db.columns db.copy db.droptable db.describe db.drivers db.execute db.select db.tables db.connect
+#not used: db.createdb db.dropdb db.databases db.droptable
+PROGRAMS = db.columns db.copy db.describe db.drivers db.execute db.select db.tables db.connect
