[GRASS-dev] drop db.droptable man page?
Markus Neteler
neteler at itc.it
Wed Nov 8 03:05:59 EST 2006
Hamish,
looks reasonable...
Markus
On Wed, Nov 08, 2006 at 07:47:17PM +1300, Hamish wrote:
> Hi,
> db.droptable's man page still gets generated even though the module has
> been removed* from the Makefile.
> * rev 1.23:
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/db/base/Makefile
> is this patch correct?
> Hamish
> Index: db/base/Makefile
> RCS file: /home/grass/grassrepository/grass6/db/base/Makefile,v
> retrieving revision 1.27
> diff -u -r1.27 Makefile
> --- db/base/Makefile 22 Sep 2006 16:30:51 -0000 1.27
> +++ db/base/Makefile 8 Nov 2006 06:45:30 -0000
> @@ -54,6 +54,6 @@
> $(BIN)/db.connect$(EXE): $(OBJDIR)/connect.o
> $(CC) $(LDFLAGS) -o $@ $(OBJDIR)/connect.o $(FMODE_OBJ) $(LIBES) $(XDRLIB) $(MATHLIB)
> -#not used: db.createdb db.dropdb db.databases
> -PROGRAMS = db.columns db.copy db.droptable db.describe db.drivers db.execute db.select db.tables db.connect
> +#not used: db.createdb db.dropdb db.databases db.droptable
> +PROGRAMS = db.columns db.copy db.describe db.drivers db.execute db.select db.tables db.connect
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
