[GRASS-dev] r.resamp.stats method=sum artifacts
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Nov 9 20:46:51 EST 2006
On Wednesday 08 November 2006 23:38, Glynn Clements wrote:
> Hamish wrote:
> > I asked earlier if r.resample should be retired, the answer was
> > "no, keep it" as `r.resamp.interp method=nearest` isn't guaranteed to
> > give exactly the same result. (but `r.mapcalc new=old` will match
> > r.resample?)
> Just about any r.* command which has a "copy mode" (i.e. some set of
> arguments which results in the output being equal to the input) will
> behave like r.resample. The core of r.resample is:
> for (row = 0; row < nrows; row++)
> if (verbose)
> G_percent (row, nrows, 2);
> if (G_get_raster_row (infd, rast, row, data_type) < 0)
> exit(1);
> if (G_put_raster_row (outfd, rast, out_type) < 0)
> exit(1);
> G_mark_raster_cats (rast, ncols, &cats, data_type);
> [Literal cut-and-paste from raster/r.resample/main.c]
> IOW, it's a get-row/put-row loop, which relies upon the automatic
> resampling performed by G_get_raster_row() etc. Any GRASS module which
> reads a raster map using the current region will have the map
> resampled in exactly the same way.
> > how about this one:
> > Should r.bilinear be tagged for retirement after GRASS 6.x?
> > (due to `r.resamp.interp method=bilinear`)
> Yes.
> Or replaced by a script which prints a "this module is deprecated"
> warning then runs "r.resamp.interp method=bilinear ...".
I think that this last option is a good migration path to a more coherent set
of resampling modules.
Thanks again Glynn for setting these up. However, I have noticed odd behavior
with r.resample.stats when the native resolution == the current resolution:
i.e. there is no difference in start/final cell size. I will start a new
thread on this topic.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
