[GRASS-dev] r.resamp.stats method=sum artifacts
Sun Nov 12 23:24:13 EST 2006
Glynn Clements wrote:
> > Should r.bilinear be tagged for retirement after GRASS 6.x?
> >   (due to `r.resamp.interp method=bilinear`)
> Yes.
> Or replaced by a script which prints a "this module is deprecated"
> warning then runs "r.resamp.interp method=bilinear ...".
warning added.
note r.bilinear has these two options which r.resamp.interp doesn't:
   north   specific input value to be assigned to the north and/or south poles for longitude-latitude grids
    east   specific input value to be assigned to the north and/or south poles for longitude-latitude grids
Hamish
