[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory error
Request Tracker grass-bugs at intevation.de
Thu Nov 9 20:31:16 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5264
Subject: v.digit - G_malloc out of memory error
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
v.digit does not respond, trying to create a new vector file results in the following error:
v.digit -n map=testv2
New empty map created.
ERROR: G_malloc: out of memory
When trying to edit an existing vector file, the following message appears:
v.digit  map=filename
ERROR: Cannot open old vector filename4 at PERMANENT on level 2
Sincerely,
Guido Lorenz
glorenz2000 at yahoo.com
-------------------------------------------- Managed by Request Tracker
