[GRASS-dev] Re: windows binaries
Fri Nov 10 07:21:43 EST 2006
Glynn Clements wrote:
> 1. I need to extend g.pnmcomp to allow it to output an alpha (mask)
> channel.
Done. The outmask= option will write the alpha channel as a PGM file.
BTW, I had to modify gis.m's mapcanvas.tcl to use output= rather than
out=, as the latter is now ambiguous.
