[GRASS-dev] Re: windows binaries
Glynn Clements
glynn at gclements.plus.com
Mon Nov 20 14:05:43 EST 2006
Hamish wrote:
> > When a d.* command is run with $GRASS_RENDER_IMMEDIATE = TRUE, it
> > generates a PPM/PGM pair with dimensions $GRASS_WIDTH * $GRASS_HEIGHT,
> > with the PPM file named $GRASS_PNGFILE and the PGM file named
> > ${GRASS_PNGFILE%.ppm}.pgm (i.e. $GRASS_PNGFILE with the .ppm suffix
> > replaced by .pgm).
> is "${GRASS_PNGFILE%.ppm}.pgm" valid for all /bin/sh or just bash?
It's specified by SUSv2:
http://www.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_06_02
and it works in ash.
> i.e. should scripts use it in preference to "`basename $file .ext1`.ext2"
> where applicable?
I'm not sure about that.
