[GRASS-dev] vector dissolve problems
Markus Neteler neteler at itc.it
Fri Nov 10 13:13:22 EST 2006
Dylan,
no, it actually used to work! Something is broken now
with the dissolving. Probably only in 6.3 due to
cats management changes?
Markus
On Fri, Nov 10, 2006 at 08:50:25AM -0800, Dylan Beaudette wrote:
> Hi Markus,
> This is a feature that would be very helpful to have in GRASS. Until
> my adventures with PostGIS, I would have to resort to using Arc-*** to
> perform this sort of "dissolve". While this functionality is simple to
> use in PostGIS, dissolve operations on VERY large datasets can be time
> consuming.
> Here is a relevant thread on the topic:
> http://www.archivesat.com/PostGIS_Users_Discussion/thread690148.htm
> Cheers,
> Dylan
> On 11/10/06, Markus Neteler <neteler at itc.it> wrote:
> >Hi,
> >I try to merge the 100km tiles of the CORINE vector
> >landcover maps which are delivered in SHAPE format.
> >Due to the tiling there are annoying boundaries now
> >when patching the tiles together. I then tried to
> >reclass and dissolve them based on the landuse
> >code to no avail.
> >Procedure:
> >for i in E43N26 E44N26 E45N26 E43N25 E44N25 E45N25
> >do
> > unzip /cdrom/data/clc00/100km$i.zip
> > v.in.ogr 100km$i.shp out=clc2000_$i
> >done
> >v.patch -e `g.mlist type=vect pat="clc2000_*" sep=,` out=clc2000_tn_bl
> ># break tile boundaries:
> >v.clean clc2000_tn_bl out=clc2000_tn_bl_clean tool=break
> ># reclass to landuse code:
> >v.reclass clc2000_tn_bl_clean out=clc2000_tn_bl_recl col=CODE_00
> ># dissolve
> >v.extract -d clc2000_tn_bl_recl out=clc2000_tn_bl_dissolved
> >The resulting map remains essentially unchanged:
> >http://mpa.itc.it/markus/tmp/vect_dissolve_troubles.png
> >Manual removal in v.digit works. But since I have 700 tiles...
> >Any ideas?
> >Markus
> >_______________________________________________
> >grass-dev mailing list
> >grass-dev at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
