[GRASS-dev] r.resamp.stats method=sum artifacts
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Nov 13 14:48:40 EST 2006
On Monday 13 November 2006 00:36, Glynn Clements wrote:
> Hamish wrote:
> > > > Should r.bilinear be tagged for retirement after GRASS 6.x?
> > > > (due to `r.resamp.interp method=bilinear`)
> > > Yes.
> > > Or replaced by a script which prints a "this module is deprecated"
> > > warning then runs "r.resamp.interp method=bilinear ...".
> > warning added.
> > note r.bilinear has these two options which r.resamp.interp doesn't:
> > north specific input value to be assigned to the north and/or south
> > poles for longitude-latitude grids east specific input value to be
> > assigned to the north and/or south poles for longitude-latitude grids
> Hmm. I suspect that the region enlargement will cause r.resamp.interp
> will fail with "Illegal latitude for North" (or South) if you try to
> resample a lat/lon map which includes either pole.
> I'm starting to wonder whether we would be better off without the
> latitude check, leaving it to up the user instead.
Would a note of caution in the man pages do the trick ?
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
