[GRASS-dev]
Re: [GRASS-CVS] glynn: grass6/lib/pngdriver Graph_set.c, 1.1,
1.2 Makefile, 1.4, 1.5 pngdriver.h, 1.3, 1.4 write.c, 1.1, 1.2
Martin Landa
landa.martin at gmail.com
Mon Nov 13 15:56:55 EST 2006
I am not able to compile pngdriver because of missing read.c, etc.
make: *** No rule to make target `OBJ.i686-pc-linux-gnu/read.o',
needed by `/usr/src/gis/grass6/dist.i686-pc-linux-gnu/lib/libgrass_pngdriver.6.3.cvs.so'.
Stop.
is there anything I have missed? Thanks!
Martin
2006/11/13, grass at intevation.de <grass at intevation.de>:
> Author: glynn
> Update of /grassrepository/grass6/lib/pngdriver
> In directory doto:/tmp/cvs-serv12051/lib/pngdriver
> Modified Files:
> Graph_set.c Makefile pngdriver.h write.c
> Log Message:
> Initialise framebuffer from $GRASS_PNGFILE if $GRASS_PNG_READ = TRUE
> Index: Graph_set.c
> RCS file: /grassrepository/grass6/lib/pngdriver/Graph_set.c,v
> retrieving revision 1.1
> retrieving revision 1.2
> diff -u -d -r1.1 -r1.2
> --- Graph_set.c 1 Jun 2006 17:40:22 -0000 1.1
> +++ Graph_set.c 13 Nov 2006 14:29:25 -0000 1.2
> @@ -92,6 +92,10 @@
> modified = 1;
> + p = getenv("GRASS_PNG_READ");
> + if (p && strcmp(p, "TRUE") == 0)
> + read_image();
> return 0;
> Index: Makefile
> RCS file: /grassrepository/grass6/lib/pngdriver/Makefile,v
> retrieving revision 1.4
> retrieving revision 1.5
> diff -u -d -r1.4 -r1.5
> --- Makefile 19 Sep 2006 10:18:48 -0000 1.4
> +++ Makefile 13 Nov 2006 14:29:25 -0000 1.5
> @@ -24,11 +24,13 @@
> Raster_RGB.o \
> Raster_int.o \
> Respond.o \
> + read.o \
> + read_ppm.o \
> write.o \
> write_ppm.o
> ifneq ($(USE_PNG),)
> - LIB_OBJS += write_png.o
> + LIB_OBJS += read_png.o write_png.o
> endif
> include $(MODULE_TOPDIR)/include/Make/Lib.make
> Index: pngdriver.h
> RCS file: /grassrepository/grass6/lib/pngdriver/pngdriver.h,v
> retrieving revision 1.3
> diff -u -d -r1.3 -r1.4
> --- pngdriver.h 19 Sep 2006 10:18:48 -0000 1.3
> +++ pngdriver.h 13 Nov 2006 14:29:25 -0000 1.4
> @@ -22,10 +22,16 @@
> extern int linewidth;
> +extern void read_image(void);
> +extern void read_ppm(void);
> +extern void read_pgm(void);
> +extern void read_png(void);
> extern void write_image(void);
> extern void write_ppm(void);
> extern void write_pgm(void);
> extern void write_png(void);
> extern void init_color_table(void);
> extern void PNG_Box_abs(int,int,int,int);
> Index: write.c
> RCS file: /grassrepository/grass6/lib/pngdriver/write.c,v
> --- write.c 1 Jun 2006 17:40:22 -0000 1.1
> +++ write.c 13 Nov 2006 14:29:25 -0000 1.2
> @@ -25,7 +25,7 @@
> write_png();
> #endif
> else
> - G_fatal_error("Graph_Close: unknown file type: %s", p);
> + G_fatal_error("write_image: unknown file type: %s", p);
> modified = 0;
> grass-commit mailing list
> grass-commit at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-commit
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
