[GRASS-dev] Re: windows binaries
Michael Barton
michael.barton at asu.edu
Mon Nov 13 19:31:05 EST 2006
Here is an updated version of d.vect.thematic for any of you to try if you
want. It is completely untested because we haven't yet been able to compile
6.3 on our new FC6 workstation with the new g.pnmcomp. We hope to get there
tomorrow but are having trouble with a mesa Glw library.
Anyway, I tried to implement Glynn's suggestions. If anyone wants to drop
this in and try it, let me know if it works.
I've also included a diff if you prefer it that way.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Mon, 13 Nov 2006 08:28:04 +0000
> To: <mlennert at club.worldonline.be>
> Cc: Paul Kelly <paul-grass at stjohnspoint.co.uk>, Michael Barton
> <michael.barton at asu.edu>, Hamish <hamish_nospam at yahoo.com>,
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] Re: windows binaries
> Moritz Lennert wrote:
>>>> 3. At the end of the script:
>>>> if [ $GRASS_RENDER_IMMEDIATE = TRUE ] ; then
>>>> if [ $GRASS_TRANSPARENT = TRUE ] ; then
>>>> g.pnmcomp \
>>>> output=$imgbase.ppm \
>>>> width=$GRASS_WIDTH \
>>>> height=$GRASS_HEIGHT \
>>>> input=$imgbase.1.ppm,$imgbase.2.ppm \
>>>> mask=$imgbase.1.pgm,$imgbase.2.pgm
>>>> else
>>>> g.pnmcomp \
>>>> fi
>>>> fi
>>> This overlays the intermediate files, with the result going to
>>> $GRASS_PNGFILE.
>> I imagine the fact that this is limited to two intermediate files is only
>> for example purposes.
> Correct.
>> As you cannot predict how many intermediate files
>> you will have, you would probably have to create the list of intermediate
>> files before and then do something like:
>> input=ListOfPPM
>> mask=ListOfPGM
> Correct.
#!/bin/sh
# MODULE: d.vect.thematic
# AUTHOR(S): Michael Barton, Arizona State University with contributions
# by Martin Landa, Jachym Cepicky, Daniel Calvelo Aros and Moritz Lennert
# PURPOSE: Displays thematic vector map with graduated colors
# or graduated points and line thickneses
# COPYRIGHT: (C) 2006 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
#%Module
#% description: Displays thematic vectormap
#% keywords: display, legend
#%End
#%option
#% key: map
#% type: string
#% gisprompt: old,vector,vector
#% description: Vector map to display thematically
#% required : yes
#%end
#%option
#% key: type
#% type: string
#% description: Vector map type
#% options: area,point,centroid,line,boundary
#% answer: area
#% required : yes
#%end
#%option
#% key: column
#% type: string
#% description: Attribute column to use for thematic display (must be numeric)
#% required : yes
#%end
#%option
#% key: themetype
#% type: string
#% options: graduated_colors,graduated_points,graduated_lines
#% answer: graduated_colors
#% description: Type of thematic display
#% required : yes
#%end
#%option
#% key: themecalc
#% type: string
#% options: interval,std_deviation,quartiles,custom_breaks
#% answer: interval
#% description: Thematic divisions of data for display
#% required : yes
#%end
#%option
#% key: breakpoints
#% type: string
#% description: Break points for custom breaks option. Separate values by spaces. (0 10 20 30 ...)
#% required : no
#%end
#%option
#% key: layer
#% type: integer
#% description: Layer to use for thematic display
#% answer: 1
#% required : no
#%end
#%option
#% key: icon
#% type: string
#% description: Vector point icon for point data
#% options: basic/box,basic/circle,basic/cross2,basic/diamond,basic/star,basic/cross1,basic/x
#% answer: basic/circle
#% required : no
#%end
#%option
#% key: size
#% type: double
#% description: Icon size for point data (minimum icon size/line width for graduated points/lines)
#% answer: 5
#% required : no
#%end
#%option
#% key: maxsize
#% type: double
#% description: Maximum icon size/line width for graduated points and lines
#% answer: 20
#% required : no
#%end
#%option
#% key: nint
#% type: integer
#% description: Number of classes for interval theme (integer)
#% answer: 4
#% required : no
#%end
#%option
#% key: colorscheme
#% type: string
#% description: Color scheme for graduated color mapping (select 'single_color' for graduated point/line display)
#% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
#% answer: blue-red
#% required : yes
#%end
#% option
#% key: pointcolor
#% type: string
#% description: Color for graduated points map (grass named color or R:G:B triplet). Set color scheme to single color.
#% answer: 255:0:0
#% required : no
#%end
#% option
#% key: linecolor
#% type: string
#% description: Color for graduated lines or point/area outlines (grass named color or R:G:B triplet). Set color scheme to single color.
#% answer: 0:0:0
#% required : no
#%end
#% option
#% key: startcolor
#% type: string
#% description: Beginning color for custom color gradient. Must be expressed as R:G:B triplet.
#% answer: 255:0:0
#% required : no
#%end
#% option
#% key: endcolor
#% type: string
#% description: Ending color for custom color gradient. Must be expressed as R:G:B triplet
#% answer: 0:0:255
#% required : no
#%end
#% option
#% key: monitor
#% type: string
#% description: Select x11 display monitor for legend
#% options: x0,x1,x2,x3,x4,x5,x6,none
#% answer: x1
#% required : no
#%end
#%option
#% key: group
#% type: string
#% gisprompt: new_file,file,group
#% description: Name of group file where thematic map commands will be saved
#% required : no
#%end
#%option
#% key: where
#% type: string
#% description: WHERE conditions of SQL statement without 'where' keyword
#% required : no
#%end
#%option
#% key: psmap
#% type: string
#% description: Root for the name of psmap instruction files to be in current directory (if not set, no psmap instruction files will be created)
#% required : no
#%end
#%flag
#% key: f
#% description: Only draw fills (no outlines) for areas and points
#%end
#%flag
#% key: u
#% description: Update color values to GRASSRGB column in attribute table
#%end
#%flag
#%key: l
#%description: Create graphic legend in x11 display monitor
#%end
#%flag
#%key: s
#%description: Use with GIS Manager (special legend and display output)
#%end
#%flag
#%key: m
#%description: Use math notation brackets in legend
#%end
#%flag
#%key: g
#%description: Save thematic map commands to group file for GIS Manager
#%end
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program."
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
PROG=`basename $0`
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
echo "$PROG: awk required, please install awk or gawk first" 2>&1
exit 1
fi
# setting environment, so that awk works properly in all languages
unset LC_ALL
export LC_NUMERIC=C
# initialize PPM file path for output and compositing with direct rendering
# (not using the PNG driver). Needed when script run within GIS Manager and Windows
imgbase=${GRASS_PNGFILE%.ppm}
rendmap=1
fi
# check column type
COLTYPE="`v.info -c $GIS_OPT_MAP layer=1 2> /dev/null | grep -w $GIS_OPT_COLUMN | cut -d'|' -f1 | tr -s '[:upper:]' '[:lower:]'`"
#COLTYPE=...
if [ -z "$COLTYPE" ] ; then
echo "ERROR: No such column [$GIS_OPT_COLUMN]"
exit 1
fi
if [ "$COLTYPE" = "integer" -o "$COLTYPE" = "double precision" ] ; then
echo ""
else
echo "ERROR: Column <$GIS_OPT_COLUMN> is of type <$COLTYPE> which is not numeric."
exit 1
fi
# create temporary file to hold output from v.univar.sh
TMP1="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP1" ] ; then
echo "ERROR: unable to create temporary file for statistics" 1>&2
exit 1
fi
# create temporary file to hold d.graph commands for legend
TMP2="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP2" ] ; then
echo "ERROR: unable to create temporary file for legend" 1>&2
exit 1
fi
# Create temporary file to commands for GIS Manager group
TMP3="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP3" ] ; then
echo "ERROR: unable to create temporary file for group" 1>&2
exit 1
fi
# Create temporary file for commands for ps.map map file
TMP4="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP4" ] ; then
echo "ERROR: unable to create temporary file for ps.map legend" 1>&2
exit 1
fi
# Create temporary file for commands for ps.map legend file
TMP5="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP5" ] ; then
exit 1
fi
# create file to hold elements for GIS Manager legend
TMP6="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP6" ] ; then
echo "ERROR: unable to create temporary file for GIS Manager legend" 1>&2
exit 1
fi
# Set display variables for group
atype=0
ptype=0
ctype=0
ltype=0
btype=0
case "$GIS_OPT_TYPE" in
"area" ) atype=1 ;;
"point" ) ptype=1 ;;
"centroid" ) ctype=1 ;;
"line" ) ltype=1 ;;
"boundary" ) btype=1 ;;
esac
cleanup()
\rm -f $TMP1 $TMP1.sort
\rm -f $TMP2 $TMP2.sort
\rm -f $TMP3 $TMP3.sort
\rm -f $TMP4 $TMP4.sort
\rm -f $TMP5 $TMP5.sort
\rm -f $TMP6 $TMP6.sort
# what to do in case of user break:
exitprocedure()
echo "User break!"
cleanup
exit 1
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
# identify current monitor or start monitor
currmon=`eval d.mon -L | grep "(selected)" | awk '{print $1}'`
if [ -z $currmon ] ; then
echo ""
echo "*** You must open a display monitor ***"
echo ""
fi
table=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $2}'`
database=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $4}'`
driver=`v.db.connect $GIS_OPT_MAP -g | grep -w $GIS_OPT_LAYER | awk '{print $5}'`
if [ -z "$table" ]
then
echo "No table connected or layer <$GIS_OPT_LAYER> doesn't exist!"
exit 1
fi
# update color values to the table?
if [ "$GIS_FLAG_U" -eq 1 ] ; then
# test, if the column GRASSRGB is in the table
if [ "`db.columns table=$table database=$database driver=$driver| grep -i grassrgb`" == "" ] ; then
echo "Creating column 'grassrgb' in table '$table'"
echo "ALTER TABLE $table ADD COLUMN grassrgb varchar(11)" | db.execute database=$database
fi
fi
# Group name
if [ -z "$GIS_OPT_GROUP" ] ; then
group="themes"
else
group=$GIS_OPT_GROUP
fi
echo "Group $group" > "$TMP3"
# Calculate statistics for thematic intervals
if [ -z "$GIS_OPT_WHERE" ] ; then
v.univar.sh -e database=$database table=$table driver=$driver column=$GIS_OPT_COLUMN > "$TMP1"
else
v.univar.sh -e database=$database table=$table driver=$driver column=$GIS_OPT_COLUMN where="$GIS_OPT_WHERE" > "$TMP1"
fi
min="`grep 'Minimum:' $TMP1 | sed s/Minimum://`"
max="`grep 'Maximum:' $TMP1 | sed s/Maximum://`"
mean="`grep 'Mean:' $TMP1 | sed s/Mean://`"
sd="`grep 'Standard deviation:' $TMP1 | sed s/'Standard deviation:'//`"
q1="`grep '1st Quartile:' $TMP1 | sed s/'1st Quartile:'//`"
q2="`grep 'Median' $TMP1 | sed s/'Median (.* N):'//`"
q3="`grep '3rd Quartile:' $TMP1 | sed s/'3rd Quartile:'//`"
q4=$max
ptsize=$GIS_OPT_SIZE
if [ -n "$GIS_OPT_BREAKPOINTS" ] && [ "$GIS_OPT_THEMECALC" != "custom_breaks" ] ; then
echo "WARNING: Custom breakpoints ignored due to themecalc setting."
fi
# set interval for each thematic map calculation type
case "$GIS_OPT_THEMECALC" in
"interval" )
numint=$GIS_OPT_NINT
step=`echo $min $max $numint | awk '{print (($2 - $1) / $3)}'`
breakpoints=`echo $min $max $numint | awk '{for(i=0;i<$3;i++){printf $1+($2-$1)/$3*i " "}printf $2}'`
annotations=""
"std_deviation" )
# 2 standard deviation units on either side of mean,
# plus min to -2 sd units and +2 sd units to max, if applicable
breakpoints=`echo $min $max $mean $sd | awk '{printf $1;for(i=-2;i<=2;i++){ith=$3+i*$4;if($1<ith && $2>ith){printf " " ith}}print " " $2}'`
annotations=`echo $min $max $mean $sd | awk '{printf "";for(i=-2;i<=2;i++){ith=$3+i*$4;if($1<ith && $2>ith){if(i!=0){printf ";"((i<0)?"":"+") i "sd"} }}print ";"}'`
numint=`echo $breakpoints | awk '{print NF-1}'`
"quartiles" )
numint=4
# one for each quartile
breakpoints="$min $q1 $q2 $q3 $max"
annotations=" q1; q2; q3; q4"
"custom_breaks" )
if [ -z "$GIS_OPT_BREAKPOINTS" ] ; then
breakpoints=`cat | awk '{gsub("[^0-9., ]","",$0);print}'`
else
breakpoints="$GIS_OPT_BREAKPOINTS"
fi
numint=`echo $breakpoints|awk '{print NF-1}'`
annotations=""
echo "Unknown themecalc type"
cleanup
exit
esac
pointstep=`echo $GIS_OPT_MAXSIZE $ptsize $numint | awk '{print (($1 - $2) / ($3-1))}'`
# legend title
echo "color 0:0:0" > "$TMP2"
echo "size 2 2" >> "$TMP2"
echo "move 1 95" >> "$TMP2"
echo "text Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP" >> "$TMP2"
echo "size 1.5 1.8" >> "$TMP2"
echo "move 4 90" >> "$TMP2"
echo "text Value range: $min - $max" >> "$TMP2"
echo "title - - - {Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP}" > "$TMP6"
echo "text 1% 95% Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP" >> "$TMP5"
echo " ref bottom left" >> $TMP5
echo "end" >> $TMP5
echo "text 4% 90% Value range: $min - $max" >> "$TMP5"
echo "end" >> $TMP5
echo "Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP"
echo ""
echo "Value range: $min - $max"
# graduated color thematic mapping
if [ "$GIS_OPT_THEMETYPE" = "graduated_colors" ] ; then
# set color schemes for graduated color maps
case "$GIS_OPT_COLORSCHEME" in
"blue-red" )
startc="0:0:255"
endc="255:0:0"
"red-blue" )
startc="255:0:0"
endc="0:0:255"
"green-red" )
startc="0:255:0"
endc="255:0:0"
"red-green" )
startc="255:0:0"
endc="0:255:0"
"blue-green" )
startc="0:0:255"
endc="0:255:0"
"green-blue" )
startc="0:255:0"
endc="0:0:255"
"cyan-yellow" )
startc="0:255:255"
endc="255:255:0"
"yellow-cyan" )
startc="255:255:0"
endc="0:255:255"
"custom_gradient" )
startc="$GIS_OPT_STARTCOLOR"
endc="$GIS_OPT_ENDCOLOR"
"single_color" )
if [ "$GIS_OPT_THEMETYPE" = "graduated_points" ]; then
startc="$GIS_OPT_LINECOLOR"
endc="$GIS_OPT_LINECOLOR"
else
startc="$GIS_OPT_POINTCOLOR"
endc="$GIS_OPT_POINTCOLOR"
fi
echo "This should not happen: gparser error. Unknown color scheme $GIS_OPT_COLORSCHEME"
cleanup
exit
esac
for i in 1 2 3; do
eval color$i=`echo $startc | cut -d':' -f$i`
eval endcolor$i=`echo $endc | cut -d':' -f$i`
done
#The number of color steps is one less then the number of classes
nclrstep=`expr $numint - 1`
clrstep1=`expr \( $color1 - $endcolor1 \) / $nclrstep`
clrstep2=`expr \( $color2 - $endcolor2 \) / $nclrstep`
clrstep3=`expr \( $color3 - $endcolor3 \) / $nclrstep`
themecolor="$startc"
# display graduated color themes
if [ "$GIS_OPT_THEMECALC" = "interval" ] ; then
echo "move 4 87" >> "$TMP2"
echo "text Mapped by $numint intervals of $step" >> "$TMP2"
echo "subtitle - - - {Mapped by $numint intervals of $step}" >> "$TMP6"
echo "text 4% 87% Mapped by $numint intervals of $step" >> "$TMP5"
echo "end" >> $TMP5
echo "Mapped by $numint intervals of $step"
fi
# display graduated color themes for standard deviation units
if [ "$GIS_OPT_THEMECALC" = "std_deviation" ] ; then
echo "text Mapped by standard deviation units of $sd (mean =$mean)" >> "$TMP2"
echo "subtitle - - - {Mapped by standard deviation units of $sd (mean =$mean)}" >> "$TMP6"
echo "text 4% 87% Mapped by standard deviation units of $sd (mean =$mean)" >> "$TMP5"
echo "end" >> $TMP5
echo "Mapped by standard deviation units of $sd (mean =$mean)"
fi
# display graduated color themes for quartiles
if [ "$GIS_OPT_THEMECALC" = "quartiles" ] ; then
echo "text Mapped by quartiles (median =$q2)" >> "$TMP2"
echo "subtitle - - - {Mapped by quartiles (median =$q2)}" >> "$TMP6"
echo "text 4% 87% Mapped by quartiles (median =$q2)" >> "$TMP5"
echo "end" >> $TMP5
echo "Mapped by quartiles (median =$q2)"
fi
echo "move 4 83" >> "$TMP2"
echo "text Color" >> "$TMP2"
echo "move 14 83" >> "$TMP2"
echo "text Value" >> "$TMP2"
echo "move 4 80" >> "$TMP2"
echo "text =====" >> "$TMP2"
echo "move 14 80" >> "$TMP2"
echo "text ============" >> "$TMP2"
echo "text 4% 83% Color" >> "$TMP5"
echo "end" >> $TMP5
echo "text 14% 83% Value" >> "$TMP5"
echo "end" >> $TMP5
echo "text 4% 80% =====" >> "$TMP5"
echo "end" >> $TMP5
echo "text 14% 80% ============" >> "$TMP5"
echo "end" >> $TMP5
echo ""
echo "Color(R:G:B)" "Value" | awk '{print $1 "\t" $2}'
echo "============" "==========" | awk '{print $1 "\t" $2}'
line1=78
line2=76
line3=75
i=1
first="true"
# if running in GUI, turn off immediate mode rendering so that the
# iterated d.vect commands will composite using the display driver
if [ "$GIS_FLAG_S" -eq 1 ] ; then
rendermode=$GRASS_RENDER_IMMEDIATE
autowrite=$GRASS_PNG_AUTO_WRITE
export GRASS_RENDER_IMMEDIATE=FALSE
export GRASS_PNG_AUTO_WRITE=FALSE
d.mon start=PNG
fi
while [ $i -le $numint ]
do
if [ "$GIS_FLAG_M" -eq 1 ] ; then
# math notation
if [ "$first" = "true" ] ; then
closebracket="]"
openbracket="["
mincomparison=">="
first="false"
else
closebracket="]"
openbracket="]"
mincomparison=">"
fi
else
closebracket=""
openbracket=""
mincomparison=">="
first="false"
else
mincomparison=">"
fi
fi
themecolor="$color1:$color2:$color3"
if [ "$GIS_FLAG_F" -eq 1 ] ; then
linecolor="none"
else
if [ "$GIS_OPT_TYPE" = "line" -o "$GIS_OPT_TYPE" = "boundary" ] ; then
linecolor=$themecolor
else
linecolor="$GIS_OPT_LINECOLOR"
fi
fi
rangemin=`echo $i $breakpoints | awk '{t=$1+1;print $t}'`
rangemax=`echo $i $breakpoints | awk '{t=$1+2;print $t}'`
if [ -z "$annotations" ]; then
extranote=""
else
extranote=`echo $annotations| cut -d';' -f$i`
fi
echo "color $themecolor" >> "$TMP2"
echo "polygon" >> "$TMP2"
echo "5 $line1" >> "$TMP2"
echo "8 $line1" >> "$TMP2"
echo "8 $line3" >> "$TMP2"
echo "5 $line3" >> "$TMP2"
echo "color $linecolor" >> "$TMP2"
echo "move 5 $line1" >> "$TMP2"
echo "draw 8 $line1" >> "$TMP2"
echo "draw 8 $line3" >> "$TMP2"
echo "draw 5 $line3" >> "$TMP2"
echo "draw 5 $line1" >> "$TMP2"
echo "move 14 $line2" >> "$TMP2"
echo "color 0:0:0" >> "$TMP2"
echo "text $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP2"
echo "area $themecolor $linecolor - {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
echo "line 5% $line1% 8% $line1%" >> $TMP5
echo " color $linecolor" >> $TMP5
echo "end" >> $TMP5
echo "text 14% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP5"
echo " ref center left" >> $TMP5
echo "end" >> $TMP5
elif [ "$GIS_OPT_TYPE" = "point" -o "$GIS_OPT_TYPE" = "centroid" ] ; then
echo "point 8% $line1%" >> "$TMP5"
echo " color $linecolor" >> "$TMP5"
echo " fcolor $themecolor" >> "$TMP5"
echo " size $GIS_OPT_SIZE" >> "$TMP5"
echo " symbol $GIS_OPT_ICON" >> "$TMP5"
echo "end" >> "$TMP5"
echo "end" >> $TMP5
else
echo "rectangle 5% $line1% 8% $line3%" >> "$TMP5"
echo " color 0:0:0" >> "$TMP5"
echo "text 14% $line3% $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP5"
echo "end" >> $TMP5
fi
echo $themecolor@$rangemin@$rangemax@$extranote@$openbracket@$closebracket | awk -F@ '{print $1 "\t\t" $5$2" - "$3$6" "$4}'
sqlwhere="$GIS_OPT_COLUMN $mincomparison $rangemin and $GIS_OPT_COLUMN<=$rangemax"
else
sqlwhere="$GIS_OPT_COLUMN $mincomparison $rangemin and $GIS_OPT_COLUMN<=$rangemax AND $GIS_OPT_WHERE"
fi
# update color to database?
if [ $GIS_FLAG_U -eq 1 ] ; then
echo "UPDATE $table SET GRASSRGB = '$themecolor' WHERE\
$sqlwhere" | db.execute database=$database
fi
# Create group for GIS Manager
if [ "$GIS_FLAG_G" -eq 1 ] ; then
# change rgb colors to hex
xthemecolor=`echo $themecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
# xlinecolor=`echo $linecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
if [ "$linecolor" = "black" ] ; then
xlinecolor="#000000"
else
xlinecolor=$xthemecolor
fi
# create group entry
echo " _check 1" >> "$TMP3"
echo " Vector $GIS_OPT_COLUMN = $rangemin - $rangemax" >> "$TMP3"
echo " map $GIS_OPT_MAP" >> "$TMP3"
echo " display_shape 1" >> "$TMP3"
echo " display_cat 0" >> "$TMP3"
echo " display_topo 0" >> "$TMP3"
echo " display_dir 0" >> "$TMP3"
echo " display_attr 0" >> "$TMP3"
echo " type_point $ptype" >> "$TMP3"
echo " type_line $ltype" >> "$TMP3"
echo " type_boundary $btype" >> "$TMP3"
echo " type_centroid $ctype" >> "$TMP3"
echo " type_area $atype" >> "$TMP3"
echo " type_face 0" >> "$TMP3"
echo " color $xlinecolor" >> "$TMP3"
echo " fcolor $xthemecolor" >> "$TMP3"
echo " width $ptsize" >> "$TMP3"
echo " _use_fcolor 1" >> "$TMP3"
echo " lcolor #000000" >> "$TMP3"
echo " sqlcolor 0" >> "$TMP3"
echo " icon $GIS_OPT_ICON" >> "$TMP3"
echo " size $ptsize" >> "$TMP3"
echo " field $GIS_OPT_LAYER" >> "$TMP3"
echo " lfield $GIS_OPT_LAYER" >> "$TMP3"
echo " attribute" >> "$TMP3"
echo " xref left" >> "$TMP3"
echo " yref center" >> "$TMP3"
echo " lsize 8" >> "$TMP3"
echo " cat" >> "$TMP3"
echo " where "$sqlwhere >> "$TMP3"
echo " _query_text 0" >> "$TMP3"
echo " _query_edit 1" >> "$TMP3"
echo " _use_where 1" >> "$TMP3"
echo " minreg" >> "$TMP3"
echo " maxreg" >> "$TMP3"
echo " _width 0.1" >> "$TMP3"
echo " End" >> "$TMP3"
fi
# display theme vector map
d.vect map=$GIS_OPT_MAP type=$GIS_OPT_TYPE layer=$GIS_OPT_LAYER \
where="$sqlwhere" \
color=$linecolor fcolor=$themecolor icon=$GIS_OPT_ICON size=$ptsize
# setting output for GIS Manager
mv $imgbase.ppm $imgbase.$num.ppm # each image needs a different number
mv $imgbase.pgm $imgbase.$rendmap.pgm
fi
rendmap+=1
fi
echo "vlines $GIS_OPT_MAP" >> $TMP4
echo " type $GIS_OPT_TYPE" >> $TMP4
echo " layer $GIS_OPT_LAYER" >> $TMP4
echo " where $sqlwhere" >> $TMP4
echo " color $linecolor" >> $TMP4
echo " label $rangemin - $rangemax" >> $TMP4
echo "end" >> $TMP4
echo "vpoints $GIS_OPT_MAP" >> $TMP4
echo " fcolor $themecolor" >> $TMP4
echo " symbol $GIS_OPT_ICON" >> $TMP4
echo "end" >> $TMP4
else
echo "vareas $GIS_OPT_MAP" >> $TMP4
echo "end" >> $TMP4
fi
# increment for next theme
let i=i+1
if [ $i = $numint ] ; then
let color1=$endcolor1
let color2=$endcolor2
let color3=$endcolor3
else
let color1=color1-clrstep1
let color2=color2-clrstep2
let color3=color3-clrstep3
fi
let line1=line1-4
let line2=line2-4
let line3=line3-4
done
# reset rendering for GUI use
d.mon stop=PNG
d.mon select=$currmon
export GRASS_RENDER_IMMEDIATE=$rendermode
export GRASS_PNG_AUTO_WRITE=$autowrite
fi
fi
#graduated points and line widths thematic mapping
if [ "$GIS_OPT_THEMETYPE" = "graduated_points" -o "$GIS_OPT_THEMETYPE" = "graduated_lines" ] ; then
#display graduated points/lines by intervals
echo "end" >> $TMP5
fi
# display graduated points/lines for standard deviation units
echo "end" >> $TMP5
fi
# display graduated points/lines for quartiles
echo "end" >> $TMP5
fi
line1=76
line2=75
echo "text Size/width" >> "$TMP2"
echo "move 25 83" >> "$TMP2"
echo "text ==============" >> "$TMP2"
echo "move 25 80" >> "$TMP2"
echo "text 4% 83% Icon size" >> "$TMP5"
echo "end" >> $TMP5
echo "text 25% 83% Value" >> "$TMP5"
echo "end" >> $TMP5
echo "text 4% 80% ============" >> "$TMP5"
echo "end" >> $TMP5
echo "text 25% 80% ============" >> "$TMP5"
echo "end" >> $TMP5
echo ""
echo "Size/width" "Value" | awk '{print $1 " " $2"\t"$3}'
echo "==========" "=====" | awk '{print $1 "\t" $2}'
themecolor=$GIS_OPT_POINTCOLOR
linecolor="none"
else
fi
i=$numint
ptsize=$GIS_OPT_MAXSIZE
# if [ "$GIS_FLAG_S" -eq 1 ] ; then
# rendermode=$GRASS_RENDER_IMMEDIATE
# autowrite=$GRASS_PNG_AUTO_WRITE
# export GRASS_RENDER_IMMEDIATE=FALSE
# export GRASS_PNG_AUTO_WRITE=FALSE
# d.mon start=PNG
# fi
while [ $i -ge 1 ]
do
# math notation
if [ "$i" = "1" ] ; then
closebracket="]"
openbracket="["
mincomparison=">="
else
closebracket="]"
openbracket="]"
mincomparison=">"
fi
else
closebracket=""
openbracket=""
mincomparison=">="
else
mincomparison=">"
fi
fi
linecolor="none"
else
fi
extranote=""
else
fi
iconsize=`echo $ptsize | awk '{print int($1 / 2)}'`
lineht=`echo $ptsize | awk '{print int($1 / 4)}'`
if [ "$lineht" -lt "4" ] ; then
lineht=4
fi
if [ "$GIS_OPT_THEMETYPE" = "graduated_lines" ]; then
echo "line $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
else
echo "point $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
fi
echo "icon + $iconsize 5 $line1" >> "$TMP2"
echo "move 10 $line2" >> "$TMP2"
echo "text $ptsize pts" >> "$TMP2"
echo "move 25 $line2" >> "$TMP2"
echo " size $iconsize" >> "$TMP5"
echo "text 25% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP5"
echo "end" >> $TMP5
echo $ptsize@$rangemin@$rangemax@$extranote@$openbracket@$closebracket | awk -F@ '{print $1 "\t\t" $5$2" - "$3$6" "$4}'
else
fi
fi
fi
#graduates line widths or point sizes
if [ "$GIS_OPT_THEMETYPE" = "graduated_lines" ] ; then
where="$sqlwhere" \
color=$linecolor fcolor=$themecolor icon=$GIS_OPT_ICON size=$ptsize \
width=$ptsize
else
where="$sqlwhere" \
fi
fi
rendmap+=1
fi
echo " size $ptsize" >> $TMP4
echo "end" >> $TMP4
ptsize=`echo $ptsize $pointstep | awk '{print $1 - $2}'`
let line1=line1-$lineht
let line2=line2-$lineht
let i=i-1
done
d.mon stop=PNG
fi
fi
# Create graphic legend
if [ "$GIS_FLAG_L" -eq 1 -a "$GIS_OPT_MONITOR" != "none" ] ; then
echo ""
echo ""
if [ `eval d.mon -L | grep $GIS_OPT_MONITOR | awk '{print $5}'` = "not" ] ; then
d.mon start=$GIS_OPT_MONITOR > /dev/null
else
d.mon select=$GIS_OPT_MONITOR > /dev/null
d.erase
fi
d.graph input=$TMP2
fi
# Create group file for GIS Manager
echo "End" >> "$TMP3"
cat $TMP3 > $group".dm"
fi
# Create ps.map map file
echo "end" >> "$TMP4"
if [ "$GIS_OPT_PSMAP" ] ; then
cat $TMP4 > $GIS_OPT_PSMAP.psmap
fi
# Create ps.map legend file
cat $TMP5 > $GIS_OPT_PSMAP\_legend.psmap
fi
# Composite thematic map for GIS Manager
compmap="$imgbase.1.ppm"
compmask="$imagebase.1.pgm"
i=2
while [ $i -le $rendmap ]
do
compmap="$compmap,$imagebase.$i.ppm"
compmask="$compmask,$imagebase.$i.pgm"
i+=1
done
g.pnmcomp \
input=$compmap \
mask=$compmask
else
g.pnmcomp \
input=$compmap
fi
fi
# Create text file to use with d.graph in GIS Manager
tmpdir=`eval dirname $TMP6`
tlegfile="$tmpdir/gismlegend.txt"
# echo $tlegfile > outtxt.txt
cp $TMP6 $tlegfile
fi
cleanup
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061113/04bc1afa/dvt_diff.obj
