[GRASS-dev] Re: windows binaries
Mon Nov 13 03:28:04 EST 2006
Moritz Lennert wrote:
> >> 3. At the end of the script:
> >> if [ $GRASS_RENDER_IMMEDIATE = TRUE ] ; then
> >>   if [ $GRASS_TRANSPARENT = TRUE ] ; then
> >>     g.pnmcomp \
> >> 	output=$imgbase.ppm \
> >> 	width=$GRASS_WIDTH \
> >> 	height=$GRASS_HEIGHT \
> >> 	input=$imgbase.1.ppm,$imgbase.2.ppm \
> >> 	mask=$imgbase.1.pgm,$imgbase.2.pgm
> >>   else
> >>     g.pnmcomp \
> >>   fi
> >> fi
> > This overlays the intermediate files, with the result going to
> > $GRASS_PNGFILE.
> I imagine the fact that this is limited to two intermediate files is only
> for example purposes.
Correct.
> As you cannot predict how many intermediate files
> you will have, you would probably have to create the list of intermediate
> files before and then do something like:
> input=ListOfPPM
> mask=ListOfPGM
Correct.
