[GRASS-dev] Re: g.proj/g.region different UTm zones
Tue Nov 14 23:19:05 EST 2006
Paul Kelly wrote:
> >> How and when was the location created?
> > Just a while ago, using the interactive region setup.
> Perhaps related to Glynn's recent changes to g.setproj then? The code was
> so complicated there it would be very easy for any changes to have
> unintended effects. One reason I have steered clear from g.setproj as much
> as possible!
I've committed this change:
--- general/g.setproj/proj-desc.table	1 Oct 2006 21:18:05 -0000	2.1
+++ general/g.setproj/proj-desc.table	15 Nov 2006 04:16:41 -0000	2.2
@@ -40,4 +40,4 @@
 WFACT:float:W:W factor
 X0:float:x_0:False Easting
 Y0:float:y_0:False Northing
-ZONE:int:zone:Projection Zone
+ZONE:zone:zone:Projection Zone
