[GRASS-dev] G_gettext initialization
Glynn Clements
glynn at gclements.plus.com
Thu Nov 16 09:15:07 EST 2006
Brad Douglas wrote:
> In G_gettext (lib/gis/locale.c), I ran across this code:
> char *
> G_gettext(const char *package, const char *msgid)
> #if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
> static char now_bound[4096];
> static int initialized;
> if (!initialized)
> initialized = 1;
> Is there any particular reason that 'initialized' is not actually
> initialized? Is there a reason for this?
I don't understand what you are asking; can you elaborate?
The above is a common idiom used to perform "one-shot" initialisation
the first time that a function is called.
