[GRASS-dev] G_gettext initialization
Thu Nov 16 18:35:29 EST 2006
> Brad wrote:
> > In G_gettext (lib/gis/locale.c), I ran across this code:
> > char *
> > G_gettext(const char *package, const char *msgid)
> > #if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
> >     static char now_bound[4096];
> >     static int initialized;
> >     if (!initialized)
> >         initialized = 1;
> > Is there any particular reason that 'initialized' is not actually
> > initialized?  Is there a reason for this?
Glynn:
> I don't understand what you are asking; can you elaborate?
> The above is a common idiom used to perform "one-shot" initialisation
> the first time that a function is called.
I think what Brad is getting at is that the "initialized" variable is
being used uninitialized in the if().
-     static int initialized;
+     static int initialized = 0;
there is humor in that.
Hamish
