[GRASS-dev] G_gettext initialization
Brad Douglas rez at touchofmadness.com
Thu Nov 16 21:34:46 EST 2006
On Fri, 2006-11-17 at 12:35 +1300, Hamish wrote:
> > Brad wrote:
> > > In G_gettext (lib/gis/locale.c), I ran across this code:
> > > char *
> > > G_gettext(const char *package, const char *msgid)
> > > #if defined(HAVE_LIBINTL_H) && defined(USE_NLS)
> > >     static char now_bound[4096];
> > >     static int initialized;
> > >     if (!initialized)
> > >         initialized = 1;
> > > Is there any particular reason that 'initialized' is not actually
> > > initialized?  Is there a reason for this?
> Glynn:
> > I don't understand what you are asking; can you elaborate?
> > The above is a common idiom used to perform "one-shot" initialisation
> > the first time that a function is called.
> I think what Brad is getting at is that the "initialized" variable is
> being used uninitialized in the if().
> -     static int initialized;
> +     static int initialized = 0;
Correct.
> there is humor in that.
Brad Douglas <rez touchofmadness com>                    KB8UYR/6
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
