[GRASS-dev] Error in redrawing text layer in gis.m
Michael Barton
Michael.Barton at asu.edu
Fri Nov 17 15:59:43 EST 2006
Great. Very glad you're not stuck with Arc.
As with most bugs, the main issue is figuring out exactly what went wrong...and this can take a LONG time.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
-----Original Message-----
Sent: Fri 11/17/2006 12:14 PM
To: Michael Barton; Hamish
Cc: grass-dev at grass.itc.it
Subject: RE: [GRASS-dev] Error in redrawing text layer in gis.m
Yes! I very happy to report this bug has been vanquished. Thanks very much Michael! Now I don't have to do all my figures in Arc.
Cheers,
~ Eric.
To: Patton, Eric; Hamish
Sent: 11/17/2006 1:30 PM
Subject: Re: [GRASS-dev] Error in redrawing text layer in gis.m
I think I found and fixed it.
It was not in grid but in the font setting environmental variable in
dtext.tcl.
The script was resetting GRASS_FONT after running d.text.new. If
GRASS_FONT
was not initially set, the script tried to set it to "". This caused a
failure in running d.frame -e for some reason. Anyway, if GRASS_FONT is
initially not set, it is unset (rather than being set to "") after
running
d.text. I think this fixes the problem.
Please test and let me know.
Michael
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
> From: "Patton, Eric" <epatton at nrcan.gc.ca>
> Date: Fri, 17 Nov 2006 09:03:35 -0500
> To: Hamish <hamish_nospam at yahoo.com>, Michael Barton
<michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>
> Conversation: [GRASS-dev] Error in redrawing text layer in gis.m
> HB:
>> Eric: any reason you aren't letting d.grid label the lines for you?
>> It should be formatted and rotated nicely (e.g. 44:26N)
>> (i.e. is there something about that you think could be improved?)
> The geogrid tool in gis.m doesn't allow you to change the font size.
So I
> wanted to draw a lat-long grid over my UTM map display, but turn off
graticule
> labels so I could use a dedicated text layer with larger labels
instead. Like
> for making screenshots and figures for reports - the default text size
of the
> geogrid labels are too small to read without squinting.
> PS - the text tool is the third button from the right on the top row
of
> buttons in gis.m.
> ~ Eric.
