[GRASS-dev] NVIZ now broken?
Michael Barton michael.barton at asu.edu
Sun Nov 19 22:31:29 EST 2006
Thanks Markus. I'm taking this to also indicate that you have no problem
with ComboBox and its labels in the vector panel.
The [G_msg "text..."] clause simply means to get the label from running the
G_msg  on some text. I think that the G_msg procedure is for helping with
internationalization. It should probably be implemented throughout NVIZ
(where it is not used at all).
It *should not* make any difference to the operation of ComboBox. If
anything, ComboBox statements using a [G_msg] clause are more likely to fail
simply because it's calling an external procedure.
That said, I'll commit a version of panel_site.tcl using [G_msg] to test
tomorrow if I can. Then we can see if this is a fix. If so, it's still a
bandaid, but at least one that is consistent with the rest of the GUI code.
My bets are on it not working.
As it is, ComboBox -label works on my Mac and on our FC4 system. It doesn't
work on your box or on at least one Windows system reported, but only in
NVIZ AFAIK.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Markus Neteler <neteler at itc.it>
> Date: Sat, 18 Nov 2006 22:05:08 +0100
> To: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] NVIZ now broken?
> Michael,
> as far as I see the ComboBox is used in a different way:
> mapprint.tcl:    ComboBox $row.c -label "" -width 20  -textvariable
> psprint::paper_preset \
> vector.tcl:    ComboBox $row.b -label [G_msg "label part to align with vector
> point"] \
> vector.tcl:    ComboBox $row.c -label [G_msg " justification"] \
> -> note G_msg in vector.tcl
> while it was in NVIZ:
> set markertype [ComboBox $row1.marker -label "  marker type " -width 8 \
> Markus
> On Sat, Nov 18, 2006 at 10:40:03AM -0700, Michael Barton wrote:
>> Paul,
>> Thanks much for the update. This  is easy to fix in nviz. The widget label
>> can be provided by a separate label widget instead of using the ComboBox
>> -label option.
>> However, I'm much more concerned about the larger issue of the version of
>> bwidgets that GRASS depends on not working correctly. This same ComboBox
>> widget with -label option is used in a number of other places in the GUI
>> (such as the GIS Manager vector layer panel).
>> If it is failing in one place (nviz) it should be failing in all places if
>> this is a general problem. If it is only failing in nviz, there is some
>> other more fundamental problem that needs to be solved or I will have no
>> idea of what kinds of GUI options work and which do not.
>> I just tried the new nviz GUI updates on our FC4 system. I still have to
>> find out which version of TclTk it is running, but nviz works
>> fine--including the ComboBox with -label option. Given Paul's message, it
>> doesn't sound like it is limited to a particular version of TclTk or OS. So
>> something else is broken.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
>>> Date: Sat, 18 Nov 2006 16:43:27 +0000 (GMT)
>>> To: Hamish <hamish_nospam at yahoo.com>
>>> Cc: <michael.barton at asu.edu>, <neteler at itc.it>, <bcovill at tekmap.ns.ca>,
>>> On Sun, 19 Nov 2006, Hamish wrote:
>>>> Markus:
>>>>>>> The tcl error is:
>>>>>>> Index: panel_site.tcl
>>>>>>> RCS file:
>>>>>> /grassrepository/grass6/visualization/nviz/scripts/panel_site.tcl,v >
>>>>>> retrieving revision 2.6 > diff -u -r2.6 panel_site.tcl
>>>>>>> --- panel_site.tcl      13 Nov 2006 16:33:33 -0000      2.6
>>>>>>> +++ panel_site.tcl      16 Nov 2006 17:05:59 -0000
>>>>>>> @@ -125,7 +125,7 @@
>>>>>>>                 -command "change_color site $row1.color"]
>>>>>>>      bind $ptcolor <Expose> "$row1.color configure -bg
>>>>>> \[get_curr_sv_color > site\]"
>>>>>>> -    set markertype [ComboBox $row1.marker -label "  marker type "
>>>>>> -width 8 \ > +    set markertype [ComboBox $row1.marker  -width 8 \
>>>>>>>         -textvariable Nv_(siteshape) -modifycmd change_marker \
>>>>>>>         -values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster"
>>>>>>> "histogram"}]
>>>>>>> -label doesn't work here.
>>>> dumb guess: what if you strip away the spaces in
>>>> to
>>>>  -label "marker type"
>>>> or
>>>>  -label "marker_type"
>>> Just tried that with various combinations of spaces and no spaces, with
>>> and without quotes. Nothing seems to work apart from deleting the -label
>>> parameter entirely...
>>> Paul
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
