[GRASS-dev] [bug #5332] (grass) crashed when i load a project
Hamish
hamish_nospam at yahoo.com
Sun Nov 26 20:42:24 EST 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5332
> Subject: crashed when i load a project
> Platform: GNU/Linux/x86_64
> grass obtained from: Mirror of Trento site
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 6.2.0-1
> Grass crashed when i will load the "spearfish60" project.
> Starting GRASS ...
> Welcome to GRASS 6.2.0 (2006)
> GRASS homepage: http://grass.itc.it/
> This version running thru: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> If required, restart the graphical user interface with: gis.m &
> When ready to quit enter: exit
> GRASS 6.2.0 (spearfish60):~ > Error in startup script: can't read
> "parts(n)": no such variable
> while executing
> "MapCanvas::zoom_new $mon $parts(n) $parts(s) $parts(e) $parts(w)
> $parts(nsres) $parts(ewres)"
g.region failed, probably because you don't have the required libraries
installed. (did you install the GDAL package(s)?)
http://grass.ibiblio.org/grass61/source/REQUIREMENTS.html
We need to catch that error better so this will send a more meaningful
error message. see:
http://thread.gmane.org/gmane.comp.gis.grass.devel/16761/focus=16850
IMO we should try and fix this for the 6.2.1 release, as it is a very
common mistake.
Hamish
