[GRASS-dev] Re: [bug #5341] (grass) v.db.select: segfault
Mon Nov 27 17:59:39 EST 2006
> Yes: use 'ddd'. The gdb backtrace I don't understand.
> 'ddd', the graphical frontend to gdb, will get you to the offending line.
> There you can check variable settings before the program crashes and so
> forth.
for ddd/kdbg instructions see  doc/debugging.txt  in the source code.
Hamish
